Fog / Driving Light Rewiring Hack, I'm having trouble figuring out which wire to ground |
LefthandRev |
Sep 7 2021, 07:02 PM
Member Group: Members Posts: 76 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
I followed these instructions for conversion #2, which should allow me to keep the fog lamps on when high beams are on... but I can't seem to get this to work.
According to these instructions, on my car, terminal one only has one blue/white wire. My car was an 08/73 build, even though the VIN shows '74. The '74 wiring info doesn't match this car (and really, all of the features of the car are '73, such as the bumper and other minor things, so I'm treating it as a '73.) Can anybody guide me on this? I'm a little boggled. Thanks! |
9146C |
Sep 8 2021, 10:50 AM
Member Group: Members Posts: 228 Joined: 14-September 19 From: US Member No.: 23,460 Region Association: None |
Just to verify, use an Ohm Meter to check the resistance of the wire you cut to pin 85 of the F/L relay...just to be sure you are grounding the correct wire.
LefthandRev |
Sep 8 2021, 11:04 AM
Just to verify, use an Ohm Meter to check the resistance of the wire you cut to pin 85 of the F/L relay...just to be sure you are grounding the correct wire. Right. Thanks... The description in the hack page isn't super clear. It's just "Do this, do that." Going to run out and check. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:30 AM |
