> Restoration Literati914 Build, A clipped car rebuild
Literati914
post Oct 24 2019, 07:56 PM
I've been putting this off, but I guess I should document the restoration build for my latest 914. I finally got the car on my property and even though there no garage (YET) I can go ahead and get some things started. This will be my 3rd 914 and it'll be a bit of a second chance for this car, as it has a front end section that's been grafted on (by PO) because of a previous accident - not to mention the rusted away hell-hole and holes in the floor. The graft actually looks pretty well done and solid, and the other items will be addressed. The car came with it's original engine - a 1.7 that's freshly rebuilt with zero miles on the rebuild (uninstalled). I've also got a 2056cc 'GA' motor that'll probably end up in this car.
The car was originally L21E Tangerine and someone's gone over it with a real crappy red paint. Since my last 914(/6) was L21E Tangerine.. I'm going to paint this one something else, and will be doing all bodywork and paint myself.
This "restoration" will be considered a driver quality effort.. but I don't plan on cutting too many corners either. I plan to do a quality job but it won't be going across the block at Christies either. Lots of parts have already been sourced, but there's always more, right! Here's the BEFORE shots:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-7222-1571968560.1.jpg)
Literati914
post Sep 12 2021, 06:31 PM
Now to tackle the loose clutch tube bracket midway down the tunnel.. in this pic a small section of the tunnel has been peeled back and my pen is pointing to where the bracket snapped, and pulled the tube towards the front of the car.
Literati914   Restoration Literati914 Build   Oct 24 2019, 07:56 PM
Literati914   UGLY FLOORS: http://www.914world.com/bbs2/uploads_...   Oct 24 2019, 08:04 PM
PlaysWithCars   You've got your hands full with that one. Alw...   Oct 25 2019, 12:21 AM
Literati914   I've not been doing much of anything to my 914...   Dec 10 2019, 07:31 PM
Literati914   Here's my replacement metal test fit: [img]htt...   Dec 10 2019, 07:34 PM
rjames   Here's my replacement metal test fit: [img]ht...   Dec 12 2019, 11:53 AM
ssuperflyoldguy   Looks like you used galvanized- bravo.   Jan 25 2020, 01:10 AM
KELTY360   Here's my replacement metal test fit: [img]ht...   Jan 25 2020, 10:20 PM
ClayPerrine   When can I come by and see it? I can bring a 914 ...   Dec 11 2019, 10:14 PM
Literati914   When can I come by and see it? I can bring a 914...   Jan 24 2020, 11:59 PM
Literati914   I was able to mess with the 914 a couple days sinc...   Jan 25 2020, 12:08 AM
Literati914   Also, I've removed all of the suspension.. for...   Jan 25 2020, 12:15 AM
Literati914   I busted most of the front suspension apart today....   Jan 25 2020, 09:02 PM
mepstein   Put a torch on the bushy gs until they smoke and t...   Jan 25 2020, 09:09 PM
Literati914   Put a torch on the bushy gs until they smoke .. g...   Jan 25 2020, 10:41 PM
bkrantz   Nice work. Every hour and step is progress.   Jan 26 2020, 10:06 PM
Literati914   OK - made some small progress lately. So the gen...   Mar 19 2020, 08:08 PM
Literati914   I know, I'm honestly terrible with documenting...   Jul 26 2021, 09:15 PM
Literati914   We're obviously in Epoxy primer and.. Got my r...   Jul 26 2021, 09:25 PM
Literati914   Oh yeah, before it got on the rotisserie I had to ...   Jul 26 2021, 09:36 PM
Literati914   ^ frustrating, when I use the forums 'attachme...   Jul 26 2021, 09:39 PM
mb911   ^ frustrating, when I use the forums 'attachm...   Jul 27 2021, 08:40 AM
TargaToy   When in the world do you sleep? In addition to th...   Jul 28 2021, 12:38 PM
Literati914   Thanks, however it’s been two years that this ca...   Jul 28 2021, 02:02 PM
Literati914   My longs are generally in good condition on this c...   Aug 10 2021, 09:41 PM
Literati914   Welded up holes from spot welds and the crack unde...   Aug 10 2021, 09:43 PM
Literati914   ..after phospho acid and primer to the inner layer...   Aug 10 2021, 09:44 PM
Literati914   Now to do the driver’s side:   Aug 10 2021, 09:46 PM
Literati914   ..in process:   Aug 10 2021, 09:50 PM
Literati914   I actually finished up just before dark :sawzall:...   Aug 10 2021, 09:57 PM
Literati914   Driver’s side long repair, done:   Aug 11 2021, 04:00 PM
Literati914   .. here’s a picture showing the reason I broke d...   Aug 11 2021, 07:30 PM
Literati914   AFTER clean up :Qarl:   Aug 11 2021, 07:31 PM
bkrantz   I can't imagine doing the underside work I did...   Aug 11 2021, 07:47 PM
Literati914   Ok so today I removed the rear under side of the t...   Aug 16 2021, 09:06 PM
Literati914   Very Loose clutch tube   Aug 16 2021, 09:13 PM
Literati914   ..both repaired   Aug 16 2021, 09:15 PM
Literati914   Here you can see marks for the cuts I made at the ...   Aug 16 2021, 09:20 PM
Literati914   Here’s a before shot of the PS inner firewall pa...   Aug 24 2021, 07:24 PM
Literati914   http://www.914world.com/bbs2/uploads_offsite/i.pos...   Aug 24 2021, 07:27 PM
Literati914   PS inner repair in process   Aug 24 2021, 07:55 PM
Literati914   ^ frustrating, when I use the forums 'attach...   Aug 24 2021, 08:20 PM
Literati914   The outside passengers firewall panel I made up fr...   Aug 24 2021, 08:47 PM
Literati914   RE: Restoration Literati914 Build   Aug 24 2021, 08:54 PM
Literati914   RE: Restoration Literati914 Build   Aug 24 2021, 08:55 PM
Literati914   RE: Restoration Literati914 Build   Aug 24 2021, 09:03 PM
tygaboy   Nice, nice work! :trophy:   Aug 24 2021, 10:52 PM
Literati914   Received a couple more items from RD, time to fini...   Sep 12 2021, 09:09 AM
Literati914   So next up.. the driver’s side inner. This time ...   Sep 12 2021, 09:17 AM
Literati914   Drivers side inner wall with holes ready to be wel...   Sep 12 2021, 09:23 AM
Literati914   The rear DS wall repair was more complicated, need...   Sep 12 2021, 09:29 AM
Literati914   Here you can see where the original ebrake tubes a...   Sep 12 2021, 09:35 AM
Literati914   …I’ll go back and dress the weld and make thin...   Sep 12 2021, 09:53 AM
Literati914   Ok so I’ve realized that when I retacked the clu...   Sep 12 2021, 10:14 AM
Literati914   …tube released   Sep 12 2021, 10:16 AM
Literati914   .. and cleaned   Sep 12 2021, 10:18 AM
Literati914   And a shot showing the remaining gap that needs fi...   Sep 12 2021, 10:31 AM
Literati914   Fabricated a panel and tacked it in.. in this pic ...   Sep 12 2021, 10:42 AM
Literati914   Spitz called himself helping, but honestly didn’...   Sep 12 2021, 11:23 AM
Literati914   Welds knocked down and lightly primed   Sep 12 2021, 06:27 PM
Literati914   Now to tackle the loose clutch tube bracket midway...   Sep 12 2021, 06:31 PM
Literati914   Bracket realigned and rewelded… I didn’t shoot...   Sep 12 2021, 06:36 PM
Literati914   Closed up, worked down and lightly primed   Sep 12 2021, 06:36 PM
bkrantz   Nice. One step at a time.   Sep 12 2021, 07:17 PM
ClayPerrine   This is amazing work. I so need to come see it in...   Sep 13 2021, 12:09 PM
Literati914   Thanks guys! Clay I look forward to having you...   Sep 13 2021, 03:13 PM
Literati914   I attached the flexible nozzle to a long flexy thi...   Sep 13 2021, 03:19 PM
Literati914   Done   Sep 13 2021, 03:20 PM
Literati914   I’ve got this stuff running out of the longs but...   Sep 13 2021, 03:24 PM
Literati914   Wanted to polish off a bottle .. no, not that kind...   Sep 13 2021, 06:07 PM
Literati914   Does anyone know if there is a reference measureme...   Sep 13 2021, 06:10 PM
ClayPerrine   Does anyone know if there is a reference measurem...   Sep 14 2021, 06:50 AM
Literati914   Yes that makes perfect since, thanks! .   Sep 14 2021, 10:23 AM
Literati914   Rusted through areas of the floor and firewalls ar...   Sep 27 2021, 07:41 PM
Literati914   In process   Sep 27 2021, 07:43 PM
Literati914   .. and completed - I’ve got solid floors again ...   Sep 27 2021, 07:44 PM
mbseto   Good persistence, good looking progress!   Sep 28 2021, 06:54 AM
Literati914   Good persistence, good looking progress! Th...   Sep 28 2021, 07:00 PM
Literati914   Here it is all buttoned up:   Sep 28 2021, 07:01 PM
Literati914   Got a couple small items checked off the list The...   Sep 30 2021, 06:51 PM
Literati914   Installed :   Sep 30 2021, 06:52 PM
Literati914   Next I fabbed up a little support bracket for the ...   Sep 30 2021, 06:54 PM
mb911   Well you did better than I. I forgot all together ...   Sep 30 2021, 06:54 PM
Literati914   .. and got that installed:   Sep 30 2021, 06:56 PM
Literati914   .. then it was on to that pesky PS rear hinge (rea...   Sep 30 2021, 06:58 PM
Literati914   Got it measured out and located properly before we...   Sep 30 2021, 07:00 PM
Literati914   The bigger accomplishment tho, was getting the cor...   Sep 30 2021, 07:05 PM
Literati914   Installed… I reused the DS one so it’s not as ...   Sep 30 2021, 07:07 PM
Literati914   Been wet for a couple days but I was able to get o...   Oct 2 2021, 07:26 PM
Literati914   After..   Oct 2 2021, 07:27 PM
Literati914   .. next I’ll be patching the huge hole in the fr...   Oct 2 2021, 07:30 PM
nivekdodge   I Have the same issue. Im thinking of making a pla...   Oct 2 2021, 07:42 PM
Literati914   I Have the same issue. Im thinking of making a pl...   Oct 2 2021, 08:24 PM
Literati914   Frunk floor replacement panel ready to install.. i...   Oct 3 2021, 06:41 PM
Literati914   .. not my best welds, as I had trouble chasing goo...   Oct 3 2021, 06:43 PM
Literati914   .. the inside side :D , I’ll go back and seem s...   Oct 3 2021, 06:44 PM
Literati914   This next issue is a doozy… this car was in a fr...   Oct 5 2021, 08:04 PM
Literati914   .. it was the same story on the driver's side,...   Oct 8 2021, 08:27 PM
Literati914   I stripped down the back side of my stock heat shi...   Oct 11 2021, 07:03 PM
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 20th November 2026 - 09:31 PM
