| nditiz1 |
Sep 15 2021, 06:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,272 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region
I will be using the patrick motorsports linkage and I am already seeing an issue. The sheet metal from restoration design looks to be using the stock location for carbs which pushes the throttle closer to the center of the engine and has the ball on the inside. CIS throttle has it on the outside. I believe some needed to drill out the ball and tap it on the opposite side. Did they also need to drill a new hole? Did anyone get it working with less effort? Maybe just drill a hole further towards the outside of the engine and not mess with the ball on the throttle shaft. Show me what you did if you can, I'm a visual learner (IMG:style_emoticons/default/beer3.gif)
Thanks all! |
| nditiz1 |
Sep 15 2021, 10:48 AM
Thanks @SirAndy
@VegasRacer - John did you drill a new hole? Looks like everything is stock. Did you use the existing hole or drill a new one? |
| VegasRacer |
Sep 15 2021, 11:06 AM
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 9,131 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None
John did you drill a new hole? Looks like everything is stock. The PO did the conversion. (IMG:style_emoticons/default/smash.gif) No extra holes that I am aware of. |
nditiz1 Pic request 914-6 conversion using CIS throttle Sep 15 2021, 06:49 AM
Root_Werks Here's a pic of my 2.7 with CIS. It uses a 4c... Sep 15 2021, 08:41 AM
Tdskip Bump for even more pictures...and a thank you to ... Sep 15 2021, 09:19 AM
SirAndy Search for the build thread of the late Jeff Tucke... Sep 15 2021, 09:52 AM
VegasRacer RE: Pic request 914-6 conversion using CIS throttle Sep 15 2021, 10:16 AM
Cairo94507 VegasRacer and Root_Werks both have clean installs... Sep 15 2021, 10:53 AM
nditiz1 Do you think you can get a shot of looking at wher... Sep 15 2021, 12:16 PM
VegasRacer
Do you think you can get a shot of looking at whe... Sep 15 2021, 11:18 PM
Steve
Do you think you can get a shot of looking at wh... Sep 15 2021, 11:25 PM
Root_Werks I think you can use a 914-6 bell crank with most o... Sep 15 2021, 01:58 PM
nditiz1 This is the issue with it lining up.
Sep 15 2021, 03:47 PM
VegasRacer AMB Racing Transponder. Sep 16 2021, 12:47 AM
ClayPerrine
Why would you put ... Sep 16 2021, 06:25 AM
VegasRacer
Why would you put the transponder that far back i... Sep 16 2021, 09:41 AM
ClayPerrine Here are some pictures from an old thread on a CIS... Sep 16 2021, 06:33 AM
nditiz1 I just drilled a hole next to the factory throttle... Sep 16 2021, 10:32 AM
VegasRacer RE: Pic request 914-6 conversion using CIS throttle Sep 16 2021, 10:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th October 2026 - 11:34 PM |
