> Pic request 914-6 conversion using CIS throttle, Thought I saved one from a past search - can't find it
nditiz1
post Sep 15 2021, 06:49 AM
I will be using the patrick motorsports linkage and I am already seeing an issue. The sheet metal from restoration design looks to be using the stock location for carbs which pushes the throttle closer to the center of the engine and has the ball on the inside. CIS throttle has it on the outside. I believe some needed to drill out the ball and tap it on the opposite side. Did they also need to drill a new hole? Did anyone get it working with less effort? Maybe just drill a hole further towards the outside of the engine and not mess with the ball on the throttle shaft. Show me what you did if you can, I'm a visual learner (IMG:style_emoticons/default/beer3.gif)
Thanks all!
nditiz1
post Sep 15 2021, 12:16 PM
Do you think you can get a shot of looking at where it passes through the rear engine tin?
nditiz1   Pic request 914-6 conversion using CIS throttle   Sep 15 2021, 06:49 AM
Root_Werks   Here's a pic of my 2.7 with CIS. It uses a 4c...   Sep 15 2021, 08:41 AM
Tdskip   Bump for even more pictures...and a thank you to ...   Sep 15 2021, 09:19 AM
SirAndy   Search for the build thread of the late Jeff Tucke...   Sep 15 2021, 09:52 AM
VegasRacer   RE: Pic request 914-6 conversion using CIS throttle   Sep 15 2021, 10:16 AM
nditiz1   Thanks @SirAndy [b]@[url=http://www.914world.c...   Sep 15 2021, 10:48 AM
VegasRacer   John did you drill a new hole? Looks like every...   Sep 15 2021, 11:06 AM
Cairo94507   VegasRacer and Root_Werks both have clean installs...   Sep 15 2021, 10:53 AM
nditiz1   Do you think you can get a shot of looking at wher...   Sep 15 2021, 12:16 PM
VegasRacer   Do you think you can get a shot of looking at whe...   Sep 15 2021, 11:18 PM
Steve   Do you think you can get a shot of looking at wh...   Sep 15 2021, 11:25 PM
Root_Werks   I think you can use a 914-6 bell crank with most o...   Sep 15 2021, 01:58 PM
nditiz1   This is the issue with it lining up.   Sep 15 2021, 03:47 PM
VegasRacer   AMB Racing Transponder.   Sep 16 2021, 12:47 AM
ClayPerrine   AMB Racing Transponder. Why would you put ...   Sep 16 2021, 06:25 AM
VegasRacer   Why would you put the transponder that far back i...   Sep 16 2021, 09:41 AM
ClayPerrine   Here are some pictures from an old thread on a CIS...   Sep 16 2021, 06:33 AM
nditiz1   I just drilled a hole next to the factory throttle...   Sep 16 2021, 10:32 AM
VegasRacer   RE: Pic request 914-6 conversion using CIS throttle   Sep 16 2021, 10:37 AM
- Lo-Fi Version Time is now: 15th October 2026 - 11:34 PM
