| Jonny Retrofit |
Sep 16 2021, 12:11 AM
Newbie ![]() Group: Members Posts: 23 Joined: 27-September 15 From: UK Member No.: 19,211 Region Association: None |
Hi Guys,
We are running 8 x 15 Fuchs on the back of our narrow body '14. With careful tyre choice and a mild fender pull this works great on the passenger side of the car. On the driver side, however, there is 5mm less clearance which appears to be a common issue. The wheels look great and I want to keep them so have been thinking about how to correct this offset. One option would be to modify the trailing arm front pivot tube. E.g. shorten on the inboard side and lengthen outboard, bringing the arm in by 5mm. Any thoughts on this approach with respect to the suspension geometry? The only thing I can think of is that the damper would be at a slightly different angle but I can't see 5mm across the length of the damper making that much difference. We don't have a rear ARB. Pretty sure the driveshaft has enough slack to cope with the 5mm reduced distance. Thoughts welcome! |
| Jonny Retrofit |
Sep 16 2021, 12:58 AM
This side is fine:
(IMG:http://www.914world.com/bbs2/uploads_offsite/cdn.shopify.com-19211-1631775966.1.jpg) |
| Superhawk996 |
Sep 16 2021, 01:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,070 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
This side is fine: (IMG:http://www.914world.com/bbs2/uploads_offsite/cdn.shopify.com-19211-1631775966.1.jpg) (IMG:style_emoticons/default/yikes.gif) Danger Will Robinson. 205/55 tire on an 8" rim are well outside Tire and Rim Association guidelines. Widest is 7 1/2" width, with recommendation for 6.5" wide rim. Lot's of bad scenarios ranging from debeading at speed to blow out from overheating of sidewalls. |
| Jonny Retrofit |
Sep 16 2021, 01:28 PM
This side is fine: (IMG:http://www.914world.com/bbs2/uploads_offsite/cdn.shopify.com-19211-1631775966.1.jpg) (IMG:style_emoticons/default/yikes.gif) Danger Will Robinson. 205/55 tire on an 8" rim are well outside Tire and Rim Association guidelines. Widest is 7 1/2" width, with recommendation for 6.5" wide rim. Lot's of bad scenarios ranging from debeading at speed to blow out from overheating of sidewalls. ‘Well outside?” Don’t think so, it’s only one tyre size away which is 10mm. In reality it doesn’t look stretched at all - picture is making it look like that. Appreciate the advice on the suspension geo which was what I was looking for. TBH, being new to 914, I did not expect to have this issue. Just my bad luck that the wheel test fit was done on the side with the space! |
Jonny Retrofit Correcting the rear wheel to fender offset. Sep 16 2021, 12:11 AM
SirAndy Thoughts welcome!
Just pull the drivers side ... Sep 16 2021, 12:35 AM
Jonny Retrofit
Thoughts welcome!
Just pull the drivers side... Sep 16 2021, 12:49 AM
LefthandRev
Thoughts welcome!
Just pull the drivers side... Sep 16 2021, 10:30 AM
[quote name='Jonny Retrofit' post='2945852' date=... Sep 16 2021, 01:10 PM
Optimusglen You going to shorten the axle 5mm too? Or potentia... Sep 16 2021, 08:21 AM
mskala Unsure of your goals and restrictions, but given t... Sep 16 2021, 08:43 AM
brant
Unsure of your goals and restrictions, but given ... Sep 16 2021, 09:23 AM
Shivers Out of the box. Is your 914 some kind of fire brea... Sep 16 2021, 09:20 AM
Jonny Retrofit Just to be clear, I don’t want to narrow the arm... Sep 16 2021, 10:45 AM
mrholland2
Just to be clear, I don’t want to narrow the ar... Sep 16 2021, 11:12 AM
jcd914 The suspension is precisely aligned with the cente... Sep 16 2021, 10:59 AM
horizontally-opposed Agree with others—the right move here is, unfort... Sep 16 2021, 11:05 AM
infraredcalvin Although I'm not a fan of stretched tires, the... Sep 16 2021, 12:18 PM
Jonny Retrofit Yes it’s the car that was on Vintage Voltage. I... Sep 16 2021, 01:04 PM
mepstein This used to happen all the time at the shop where... Sep 16 2021, 01:08 PM
914e @Jonny Retrofit My rear fender clearance varied c... Sep 16 2021, 01:35 PM
rhodyguy Try a baseball bat. Or in your case a cricket bat ... Sep 16 2021, 01:48 PM
targa72e I did similar to 914E but used plywood against the... Sep 17 2021, 08:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st September 2026 - 03:12 AM |
