fuel pump question |
Joec |
Sep 18 2021, 02:19 PM
Newbie Group: Members Posts: 16 Joined: 26-April 21 From: Delta, BC Member No.: 25,484 Region Association: None |
I am relocating the fuel pump to the front of the car below the gas tank. I am using a bosch fuel pump #69133. Will I need a fuel pressure regulator?
jcd914 |
Sep 19 2021, 12:14 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
It depends on the fuel injection type, D-jet is 29 psi I believe and L-jet has 2 pressure checks, running at idle with vacuum hose connected and without the vacuum hose connected, I don't remember the specs. From your description it sounds like you will be going through the whole injection system. Good Luck Jim |
Lo-Fi Version | Time is now: 9th June 2024 - 07:56 AM |
