fuel pump question |
Joec |
Sep 18 2021, 02:19 PM
Newbie Group: Members Posts: 16 Joined: 26-April 21 From: Delta, BC Member No.: 25,484 Region Association: None |
I am relocating the fuel pump to the front of the car below the gas tank. I am using a bosch fuel pump #69133. Will I need a fuel pressure regulator?
Joec |
Sep 19 2021, 12:23 PM
Found the oem pressure regulator, disconnected for some reason. Any reason not to use it? are they prone to failure?
Tdskip |
Sep 19 2021, 05:57 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Found the oem pressure regulator, disconnected for some reason. Any reason not to use it? are they prone to failure? Generally these are very reliable, now what has happen to your over the past 45+ years may be a different thing. You can always run it and check it with a pressure gauge. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:35 AM |
