bumper bolt strength, will 8.8's be strong enough for temporary use? |
914lover17 |
Sep 20 2021, 06:14 PM
Newbie Group: Members Posts: 45 Joined: 11-June 21 From: Kitchener-Waterloo Member No.: 25,622 Region Association: Canada |
My bolts are in pretty bad shape, looks like they have been cut down from unoriginal longer bolts. Some aren't fitting, even with the bumper off.
I am going to lightly tap the nuts and wanto get replacement bolts/rubber biscuit spacers. Are the 8.8 class m8 x 40mm bolts from the hardware store good enough for temporary use while I order the correct 10.9 class ones? the ones inside it now are 9.8. example of correct OEM: https://www.justkampers.com/n0103404-m8-x-4...rious-uses.html Temporary option: https://www.homedepot.ca/product/paulin-m8-...ated/1000135048 |
mepstein |
Sep 20 2021, 07:28 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Some people use threaded studs to make hanging the bumper easier.
bkrantz |
Sep 20 2021, 07:31 PM
914 Guru Group: Members Posts: 7,804 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Some people use threaded studs to make hanging the bumper easier. But then they miss out on the fun of single-handed supporting a bumper in place while trying to get a bolt on each side started. (IMG:style_emoticons/default/headbang.gif) |
mepstein |
Sep 20 2021, 07:37 PM
Some people use threaded studs to make hanging the bumper easier. But then they miss out on the fun of single-handed supporting a bumper in place while trying to get a bolt on each side started. (IMG:style_emoticons/default/headbang.gif) Actually not to hard if you can find a large cardboard box to sit it on. Also works well for removing. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:10 AM |
