moshman53 |
Newbie ![]() Group: Members Posts: 6 Joined: 23-September 21 From: Durango, Colorado Member No.: 25,932 Region Association: Southwest Region ![]() |
Greetings!
I’ve owned this ‘73 since 2000 and have looked after it as a daily driver for years. It’s now time to let it go. I initially never had concerns with a Salvage Title, but now realize just how important it is and that it’ll never really go away. 1973 Porsche 914 2.0 - Salvage Title - Purchased in 2000 for $5,000 84,000 miles Vin Numbers match throughout. Delphi Green Metallic (repainted, with original color) Vinyl-covered roll bar Dual horns Chrome bumpers Fog lights 5 1/2" X 15 Fuchs wheels 165/15 tires Leather-covered steering wheel and shift knob Center Console Center arm rest with storage compartment Original Blaupunkt Radio Dual Weber Carb installed (saved original D-Jet too.) Engine runs great Transmission solid Brakes solid Moderate rust, but nothing structural except the Left Rocker Panel - rust from battery Seats have torn/broken vinyl I’m reaching out for some creative feedback regarding what I might ask for this car…or more importantly, what I might get for this car! Thanks In advance!! Mōsh in Durango Attached thumbnail(s) ![]() ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,958 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
The front cowl rust is bad. That’s a pita spot to repair.
The sail panel rust is bad. Common spot due to the foam inside the targa bar. Rust at the rear trunk is common because water would always sit in the lowest point. The longitudinal rust is bad. The long is made of multiple layers of metal and is always a bigger repair than you think. Chances are the right rear suspension consoles need work. There is probably a lot more going on that will be exposed when these repairs are initiated. I’ll revise my estimate back to single digits. It’s a car that should be restored but will take a lot of work to get there. |
moshman53 |
The front cowl rust is bad. That’s a pita spot to repair. The sail panel rust is bad. Common spot due to the foam inside the targa bar. Rust at the rear trunk is common because water would always sit in the lowest point. The longitudinal rust is bad. The long is made of multiple layers of metal and is always a bigger repair than you think. Chances are the right rear suspension consoles need work. There is probably a lot more going on that will be exposed when these repairs are initiated. I’ll revise my estimate back to single digits. It’s a car that should be restored but will take a lot of work to get there. Thanks, these were my “deep” thoughts too. I had planned and really felt the car needed to be stripped of all to bare body and properly “de rusted” top to bottom inside and out. |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
The front cowl rust is bad. That’s a pita spot to repair. The sail panel rust is bad. Common spot due to the foam inside the targa bar. Rust at the rear trunk is common because water would always sit in the lowest point. The longitudinal rust is bad. The long is made of multiple layers of metal and is always a bigger repair than you think. Chances are the right rear suspension consoles need work. There is probably a lot more going on that will be exposed when these repairs are initiated. I’ll revise my estimate back to single digits. It’s a car that should be restored but will take a lot of work to get there. Thanks, these were my “deep” thoughts too. I had planned and really felt the car needed to be stripped of all to bare body and properly “de rusted” top to bottom inside and out. And if you completed everything on Mark's list, you would have still replaced less of the original metal than I did on my car with a clean title. That says something about how a salvage title should affect value. I agree that good documentation of any repairs and restoration should be the most important documentation for a prospective buyer. |
Lo-Fi Version | Time is now: 9th July 2025 - 11:59 AM |
