partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Anyone have any pictures of what has been done for a console that works with the 6 speed Boxster setup?
If I use the Boxster console, looks like I would have to somehow patch in where the electricals were, and the handbrake. To get it to set back far enough, I would probably have to cut about 3" off the bottom of the center backpad, but then may not be able to open the console door, or take a section out of the length of the console. How easy is it to mend it back together and make it look like something? Also, will the factory rear sway bar, fit if using the 6 speed boxster trans? ![]() ![]() ![]() ![]() ![]() ![]() |
Gearup |
Member ![]() ![]() Group: Members Posts: 157 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None ![]() |
Anyone have any pictures of what has been done for a console that works with the 6 speed Boxster setup? If I use the Boxster console, looks like I would have to somehow patch in where the electricals were, and the handbrake. To get it to set back far enough, I would probably have to cut about 3" off the bottom of the center backpad, but then may not be able to open the console door, or take a section out of the length of the console. How easy is it to mend it back together and make it look like something? Also, will the factory rear sway bar, fit if using the 6 speed boxster trans? Nice looking setup. Is that an LS with a holly intake? Are those Renegade adapter Parts? Brett |
Lo-Fi Version | Time is now: 15th June 2024 - 07:45 PM |
