| partwerks |
Sep 24 2021, 07:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Are there any pads that go under where the gas tank sits to keep it from rubbing?
If so, any pictures of where they are placed? |
| 914sgofast2 |
Sep 25 2021, 01:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 796 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Any type of foam pad should be avoided. They will retain moisture and rust out the tank from the outside to the inside. I am using a sheet of epdm rubber I got from Grainger Supply and cut to fit the shape I wanted. It has adhesive on one side and was glued to the body, not the tank. People also use pieces of the green scotchbrite scouring pads, but they too will retain moisture.
| bkrantz |
Sep 27 2021, 07:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Any type of foam pad should be avoided. They will retain moisture and rust out the tank from the outside to the inside. I am using a sheet of epdm rubber I got from Grainger Supply and cut to fit the shape I wanted. It has adhesive on one side and was glued to the body, not the tank. People also use pieces of the green scotchbrite scouring pads, but they too will retain moisture. I did the same, with non-adhesive neoprene rubber sheet material. |
partwerks Gas tank pads Sep 24 2021, 07:56 PM
mepstein Yes, 3 pads. Sorry, I don’t have pics. Sep 24 2021, 08:01 PM
partwerks http://www.914world.com/bbs2/index.php?sho...=3556... Sep 24 2021, 09:55 PM
partwerks Looks like a pad on the DS back, two places on the... Sep 24 2021, 10:15 PM
sholman5
I bought the pads Lowes. Sep 25 2021, 06:07 AM
partwerks
I wonder if it would ... Sep 25 2021, 08:07 AM
partwerks I wonder if there would be local places that carry... Sep 25 2021, 09:59 PM
sixnotfour I add a pad as noted in your pic.. rusty spot Sep 25 2021, 10:29 PM
partwerks Which size/thickness EPDM in particular do they us... Sep 27 2021, 06:38 PM
Front yard mechanic I only use German pads super soft and slim Sep 27 2021, 07:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:36 PM |
