> Distributors and Trigger Points (New Dizzy Installed), Troubleshooting Parts - CHT appears bad
tvdinnerbythepool
post Sep 9 2021, 08:43 AM
Hey all,
I am still chasing down an intermittent RICH condition when the car is fully warmed up. 1.7L D-Jet
After fully warmed up with a tuned and rebuilt MPS I can come to a stop light and idle steady at 850rpms, next stop light it's bogging down to almost 200-300 and barely running. Then next light it's idling normally again. Some days I have no issues with idle at all, others I do.
I've gone through all the components and troubleshot my way through everything on the PBANDERS list of "my car is running rich". I am as confident as I can be through extensive troubleshooting and testing that my ECU, AAR, MPS, CSV, Vacuum Leaks, CHT, Injectors, Fuel Pressure etc are all good. All new wiring harnesses, plugs, plug wires, cap, rotor, coil, etc.
The ONLY thing I haven't worked on is the distributor.
I am reading up on the possibility of the Trigger Sensor Contacts being warn and bouncing possibly shooting off extra injection pulses...could this be the cause of the intermittent problem?
It doesn't have points anymore, but a petronix I believe.
What do you guys think? Is there an easy test for this or do I replace the trigger contacts or the whole dizzy?
Cheers! (IMG:style_emoticons/default/beerchug.gif)
tvdinnerbythepool
post Sep 29 2021, 11:56 AM
What are peoples experiences between the URO (part 041) vs the 914rubber (part 012)?
I'm always the first to support Mark and the guys over at 914...maybe I just got an intermittent sensor which I've heard is not unusual.
tvdinnerbythepool   Distributors and Trigger Points (New Dizzy Installed)   Sep 9 2021, 08:43 AM
yellowporky   Did you resolve this? You don’t mention the TPS?...   Sep 13 2021, 11:35 AM
r_towle   Remove, clean and regrease the distributor advance...   Sep 13 2021, 05:34 PM
rjames   How did you tune the rebuild MPS? Typically afte...   Sep 13 2021, 09:37 PM
Rand   MPS wouldn't likely be intermittent like that....   Sep 13 2021, 10:09 PM
rjames   MPS wouldn't likely be intermittent like that...   Sep 15 2021, 07:33 PM
Arno914   I have the same issue with my 71-4. Checked every...   Sep 14 2021, 01:57 AM
tvdinnerbythepool   Hey guys! Thanks for everyone's response....   Sep 14 2021, 07:45 AM
tvdinnerbythepool   Shaft crud upon removal   Sep 14 2021, 07:45 AM
tvdinnerbythepool   Clean baby!   Sep 14 2021, 07:46 AM
914_teener   That dizzy is worn. Look at the plate on the trig...   Sep 14 2021, 10:02 AM
tvdinnerbythepool   @914_teener I take it you are referring to the ci...   Sep 14 2021, 03:20 PM
914_teener   What do you think? That's normal? So you thi...   Sep 14 2021, 04:13 PM
tvdinnerbythepool   I didn't think it was necessarily normal, but ...   Sep 14 2021, 04:29 PM
914_teener   I didn't think it was necessarily normal, but...   Sep 14 2021, 04:40 PM
Jett   We recently sent our distributor out for rebuildâ€...   Sep 14 2021, 05:44 PM
tvdinnerbythepool   @jett thanks for the info and link [b]@[url=htt...   Sep 14 2021, 08:56 PM
r_towle   So, does the odd idle condition still happen? Adva...   Sep 14 2021, 09:03 PM
tvdinnerbythepool   @r_towle will try and fire it up tomorrow. Only h...   Sep 14 2021, 09:15 PM
tvdinnerbythepool   @r_towle will try and fire it up tomorrow. Only h...   Sep 14 2021, 09:18 PM
r_towle   It’s the advance plates that the points mount to...   Sep 14 2021, 11:06 PM
tvdinnerbythepool   Agreed, that grease hadn't been grease for a w...   Sep 15 2021, 08:28 AM
Solocholo   It’s the advance plates that the points mount t...   Sep 21 2021, 12:45 PM
Solocholo   It’s the advance plates that the points mount ...   Sep 21 2021, 12:46 PM
Solocholo   It’s the advance plates that the points mount ...   Sep 21 2021, 12:47 PM
Solocholo   [quote name='Solocholo' post='2947227' date='Sep ...   Sep 21 2021, 12:48 PM
tvdinnerbythepool   @Solocholo Dang! At least we aren't the o...   Sep 22 2021, 06:30 PM
tvdinnerbythepool   Ok guys, I bought the 123 Dizzy, Bluetooth and all...   Sep 22 2021, 06:33 PM
bobboinski   Black advance Green retard   Sep 22 2021, 07:57 PM
tvdinnerbythepool   @bobboinski thx!   Sep 23 2021, 08:29 AM
tvdinnerbythepool   @Solocholo it looks like the contacts for your FI...   Sep 23 2021, 08:42 AM
nordfisch   Hi to all, the 123 has a big disadvantage you shou...   Sep 26 2021, 02:34 AM
emerygt350   Hmmm, I read that the original design set the inje...   Sep 26 2021, 05:21 AM
tvdinnerbythepool   Got the distributor installed, I opted for the Blu...   Sep 27 2021, 04:10 PM
emerygt350   Nothing you can download from the website? Really...   Sep 27 2021, 05:30 PM
bobboinski   Does this help? Around post #102 #132. http://www...   Sep 27 2021, 06:55 PM
tvdinnerbythepool   Hey Guys, Thanks for the response. Long story shor...   Sep 27 2021, 08:49 PM
r_towle   Here is how I would troubleshoot this. 1) put orig...   Sep 27 2021, 09:08 PM
r_towle   If all those tests pass, you have and air leak or ...   Sep 27 2021, 09:12 PM
JamesM   If all those tests pass, you have and air leak or...   Sep 27 2021, 10:57 PM
emerygt350   All great suggestions, and I would start with the ...   Sep 28 2021, 05:41 AM
tvdinnerbythepool   Thanks all. I've made a list with the above an...   Sep 28 2021, 09:26 AM
tvdinnerbythepool   CHT cold (63 degrees F) 49.5K ohms Well...there...   Sep 29 2021, 11:31 AM
tvdinnerbythepool   What are peoples experiences between the URO (part...   Sep 29 2021, 11:56 AM
emerygt350   I would start with that blow by (compression test)...   Sep 29 2021, 01:15 PM
tvdinnerbythepool   Update below CHT: measured 49.7K Ohms at 63 degre...   Sep 30 2021, 03:00 PM
DRPHIL914   Update below CHT: measured 49.7K Ohms at 63 degr...   Oct 1 2021, 11:10 AM
emerygt350   The engine is designed with particular vacuum leak...   Oct 1 2021, 07:44 AM
tvdinnerbythepool   @emerygt350 idle screw does work and is very effe...   Oct 1 2021, 12:28 PM
emerygt350   If the idle screw works can you bring the idle up ...   Oct 1 2021, 03:44 PM
tvdinnerbythepool   If the idle screw works can you bring the idle up...   Oct 1 2021, 09:00 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:44 AM
