partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Anyone have any pictures of what has been done for a console that works with the 6 speed Boxster setup?
If I use the Boxster console, looks like I would have to somehow patch in where the electricals were, and the handbrake. To get it to set back far enough, I would probably have to cut about 3" off the bottom of the center backpad, but then may not be able to open the console door, or take a section out of the length of the console. How easy is it to mend it back together and make it look like something? Also, will the factory rear sway bar, fit if using the 6 speed boxster trans? ![]() ![]() ![]() ![]() ![]() ![]() |
Gearup |
Member ![]() ![]() Group: Members Posts: 157 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None ![]() |
Anyone have any pictures of what has been done for a console that works with the 6 speed Boxster setup? If I use the Boxster console, looks like I would have to somehow patch in where the electricals were, and the handbrake. To get it to set back far enough, I would probably have to cut about 3" off the bottom of the center backpad, but then may not be able to open the console door, or take a section out of the length of the console. How easy is it to mend it back together and make it look like something? Also, will the factory rear sway bar, fit if using the 6 speed boxster trans? Nice looking setup. Is that an LS with a holly intake? Are those Renegade adapter Parts? Brett |
partwerks |
Anyone have any pictures of what has been done for a console that works with the 6 speed Boxster setup? If I use the Boxster console, looks like I would have to somehow patch in where the electricals were, and the handbrake. To get it to set back far enough, I would probably have to cut about 3" off the bottom of the center backpad, but then may not be able to open the console door, or take a section out of the length of the console. How easy is it to mend it back together and make it look like something? Also, will the factory rear sway bar, fit if using the 6 speed boxster trans? Nice looking setup. Is that an LS with a holly intake? Are those Renegade adapter Parts? Brett It's an LS3 with a hot cam. Holley intake, with 90 degree elbow. You have to use aftermarket fuel rails also. Otherwise you won't be able to close the casket lid. I got the adapter plate, clutch and pressure plate from Eric at: http://www.kitcarchassis.com/ Much easier on the pocket book. I think you can have the hole for an LS starter, or go with the one he sells with it. I got the motor mount bar and trans bracket from Renegade. I think I could have used my old motor mount bar, but wanted to make sure that it was sitting correctly so it would sit low enough, (the intake) since they have already pioneered the way. |
djway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California ![]() |
Much easier on the pocket book. I think you can have the hole for an LS starter, or go with the one he sells with it. What is the price for the adapter? The web site doesn't even list the boxter adapter being completed. |
partwerks |
I got the adapter plate, clutch and pressure plate from Eric at: http://www.kitcarchassis.com/ Much easier on the pocket book. I think you can have the hole for an LS starter, or go with the one he sells with it. What is the price for the adapter? The web site doesn't even list the boxter adapter being completed. I don't recall. I'm reworking some X mechanic stuff, and started this in Sept of 2014, and don't recall off the top. He's cheaper than Kennedy. I can tell you that! 214-606-2457 is his number. Eric is his first name. I think he can put the hole for a LS starter in if you want also, rather than that other one he offers. |
Lo-Fi Version | Time is now: 15th June 2024 - 06:56 PM |
