| roberthbollinger |
Oct 1 2021, 04:54 PM
Newbie ![]() Group: Members Posts: 3 Joined: 16-March 10 From: Nipomo, CA Member No.: 11,475 Region Association: Central California |
I want to replace the anodized stainless roll bar trim on my 1973 914. The top has a philips head screw, however, the bottom has a clip/spacer that is no longer produced. Does the trim have adhesive to hold it in place? How can I avoid damaging the vinal sail panel and reinstall the new trim? How can I save the clip/spacer at the bottom of the trim?
Thank you, Bob Bollinger Roberthbollinger@aol.com |
| iankarr |
Oct 1 2021, 04:59 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,595 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
I want to replace the anodized stainless roll bar trim on my 1973 914. The top has a philips head screw, however, the bottom has a clip/spacer that is no longer produced. Does the trim have adhesive to hold it in place? How can I avoid damaging the vinal sail panel and reinstall the new trim? How can I save the clip/spacer at the bottom of the trim? Thank you, Bob Bollinger Roberthbollinger@aol.com I just did this. Auto Atlanta sells the clips, but the stud is too short to get a nut on in the wheel well. Frustrating. I used a bolt through a right-sized washer that fits in the slot at the bottom of the trim. Used a little butyl to hold the bolt to the washer (jb weld would work better) and Bob’s your uncle. Note that the screw at the top has a spacer behind it so you don’t bend the trim when tightening. |
| windforfun |
Oct 2 2021, 11:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,097 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
I want to replace the anodized stainless roll bar trim on my 1973 914. The top has a philips head screw, however, the bottom has a clip/spacer that is no longer produced. Does the trim have adhesive to hold it in place? How can I avoid damaging the vinal sail panel and reinstall the new trim? How can I save the clip/spacer at the bottom of the trim? Thank you, Bob Bollinger Roberthbollinger@aol.com I just did this. Auto Atlanta sells the clips, but the stud is too short to get a nut on in the wheel well. Frustrating. I used a bolt through a right-sized washer that fits in the slot at the bottom of the trim. Used a little butyl to hold the bolt to the washer (jb weld would work better) and Bob’s your uncle. Note that the screw at the top has a spacer behind it so you don’t bend the trim when tightening. Note that the spacer has one flat side & one cupped side. The later points out & the cup is for countersinking the screw. Also, for the bottom, use a nut (M4 IIRC) with a captive lock washer & a socket head with a swivel. |
roberthbollinger Replacing Roll Bar Stainless Trim L/R sides Oct 1 2021, 04:54 PM
rhodyguy The nut for the clip/spacer is located in the top ... Oct 1 2021, 04:59 PM
bkrantz
The nut for the clip/spacer is located in the top... Oct 1 2021, 07:28 PM
Mikey914 Got you covered
https://914rubber.com/roll-bar-t... Oct 1 2021, 04:59 PM
iankarr 914 rubber to the rescue. Didn’t realize those w... Oct 1 2021, 05:05 PM
914werke was puzzled by the title as what is described as s... Oct 1 2021, 06:25 PM
mepstein Get some good light in there and it will help. Oct 1 2021, 07:59 PM
Mikey914 Our next round on these we will make the "bol... Oct 1 2021, 09:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:14 PM |
