> Main Targa Seal Install, A/K/A Defeated by rubber
johnlush
post Mar 28 2019, 05:56 PM
What's all this then?
After way too many hours on this I'm out of ideas. Yes, I've searched and it looks like struggling with the installation of the main targa seal is part of the game but it is possible. That has not been my experience. I got the right a-pillar portion installed by sliding it down from the top although everything I've read said that wouldn't work and to seat the inside lip in the channel and work the outer lip into the trim with a suitable tool. So far so good and off to the left side. Nothing and I mean nothing works. Tried sliding from the top and it binds about a third of the way in and will go no further. I've already examined the track for dings and crud and it's clean and mostly straight. So I give up on that idea and decide OK, let's do the one lip at a time thing. I can't get it to start using anything I try. I have flat nylon tools, screwdrivers, putty knives, you name. it.
I've heard it alluded to that there are pictures and/or videos of how the #%^& to do this but I can't find them.
Any words of wisdom would be greatly appreciated...
Mikey914
post Sep 28 2020, 02:10 PM
The rubber man
Even f you are missing the tab, you can make adjustments by anchoring the corners with the screw that holds it and starting the section on the track side and pulling to set the angle where it's correct before doing the entire track.
Mark
Costa05
post Oct 7 2021, 08:15 PM
QUOTE(Mikey914 @ Sep 28 2020, 03:10 PM) *
Mark
Did the @mikey914 method this evening and it was not that bad once you develop a rhythm. Tabs were missing on mine. Went for it anyways. 2 hrs and done. Was fortunate my windshield is out as a quick clamp came in handy to pull the rubber tight into the small radius section at the top which was the tough part. Tool of choice was an old painters scraper dulled down on the edge. Used the square pointed corner to push and feed the rubber into the outer channel edge small bites at a time. Glycerin for the lube. Thank you all for the posts on this thread.
johnlush   Main Targa Seal Install   Mar 28 2019, 05:56 PM
mgphoto   Sex lube, water soluble. ie: Astro Glide   Mar 28 2019, 06:16 PM
JeffBowlsby   Glycerin is your friend. Careful to not tear the ...   Mar 28 2019, 06:21 PM
johnlush   I tried silicone paste - is water-based stuff any ...   Mar 28 2019, 07:35 PM
Chi-town   Most silicone paste have petroleum additives which...   Mar 28 2019, 08:40 PM
second wind   [quote name='Chi-town' date='Mar 28 20...   Oct 7 2021, 11:51 PM
tomh   I was able to do it by pushing slowly and steadily...   Mar 28 2019, 10:37 PM
Mblizzard   I added heat from a hair drier to make it a bit mo...   Mar 29 2019, 06:20 AM
rhodyguy   Buy the big container of glycerin at Riteaid. It d...   Mar 29 2019, 07:17 AM
dr914@autoatlanta.com   it needs to fit tightly to seal, silicone grease b...   Mar 29 2019, 08:42 AM
Mikey914   We do it a little differently. You can install the...   Mar 29 2019, 08:49 AM
johnlush   Thought I'd update this. It's in. I ended ...   Mar 30 2019, 05:10 PM
Mikey914   :beer3: :beer3: :beer3: Yes , not a super easy j...   Mar 31 2019, 12:58 PM
RiqueMar   :beer3: :beer3: :beer3: Yes , not a super easy ...   May 20 2020, 12:03 PM
bbrock   Just my 2 cents - Porsche recommended glycerine fo...   May 20 2020, 12:14 PM
ValcoOscar   I saw a recent video where Matt from 914Rubber ins...   May 20 2020, 12:26 PM
RiqueMar   I saw a recent video where Matt from 914Rubber in...   May 20 2020, 12:32 PM
ValcoOscar   @[url=http://www.914world.com/bbs2/index.php?showu...   May 20 2020, 12:33 PM
RiqueMar   @[url=http://www.914world.com/bbs2/index.php?show...   May 20 2020, 12:41 PM
cpavlenko   I'll be doing this seal in a few weeks. I got ...   May 20 2020, 01:16 PM
PCH   Here's my experience: I thought I 'd save...   May 20 2020, 02:18 PM
horizontally-opposed   I remember the first time I worked on it, I had al...   May 20 2020, 02:33 PM
Mikey914   Watch the video. The real key is that you DO NOT p...   May 20 2020, 06:54 PM
RiqueMar   Watch the video. The real key is that you DO NOT ...   May 21 2020, 12:06 PM
cpavlenko   [quote name='Mikey914' post='2817316' date='May 2...   May 21 2020, 01:25 PM
914e   Watch the video. The real key is that you DO NOT ...   Sep 28 2020, 01:12 PM
cuddy_k   Congrats!   May 21 2020, 01:18 PM
pete000   I was able to do mine with out too much drama. Not...   May 21 2020, 02:57 PM
chandler1969   Replacing mine after ignoring for 10 years. I neve...   Sep 28 2020, 12:49 PM
IronHillRestorations   The original part has a slot in the top corners fo...   Sep 28 2020, 01:31 PM
Mikey914   Even f you are missing the tab, you can make adjus...   Sep 28 2020, 02:10 PM
chandler1969   Even f you are missing the tab, you can make adju...   Sep 28 2020, 02:48 PM
rbzymek   Even f you are missing the tab, you can make adj...   Sep 28 2020, 03:34 PM
Costa05   Even f you are missing the tab, you can make adju...   Oct 7 2021, 08:15 PM
chandler1969   Got the top seal in. I think it turned out nice. S...   Sep 29 2020, 02:07 PM
Mikey914   I’ll source those this week and drop you some if...   Sep 29 2020, 10:06 PM
horizontally-opposed   Pulled the Porsche Classic seal yesterday, which w...   Jun 21 2021, 08:11 AM
Mikey914   It's not really a difficult seal to install, i...   Oct 7 2021, 10:59 PM
- Lo-Fi Version Time is now: 16th June 2024 - 07:34 PM
