| Tdskip |
Oct 14 2021, 10:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Good morning, hope everybody’s having a decent day so far. The red homebrew ex-turbo car has a front mounted oil cooler and lines that were run up the passenger side of the car. I am considering putting a 3.2L 911 engine in it and would like to, obviously, reuse as much of the existing work That was already done to the car as possible.
I believe using the lines as-is that are picked up forward of the rear passenger wheel it’s just a matter of getting all the hard lines custom fit and routing to/from the thermostat? In other words I’m going to have some custom wines to make but there’s nothing inherently good/bad about routing everything up the passenger side rather than the driver side, right? Thanks! (thanks for being patient with all the questions about this car over the years, I’ve managed to acquire a couple 911 engines and shells and I’m trying to play Legos with getting the build combinations right) |
| roblav1 |
Oct 14 2021, 12:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I did mine with flex AN12 lines on the left... under the steel rocker panel, through to the left front wheelwell, through the inner wheelwell panel near the brake fluid resevoir, down into the fuel tank cavity, through the left box section there, and through the back bulkhead of the front trunk.
A hole saw is my friend! The only real mod I needed to make was increase the clearance at the top left rear of the fuel tank. One AN12 hose easily fits. The mod needed to accomodate two. |
Tdskip Oil lines up the passenger side for 914/6v Oct 14 2021, 10:41 AM
JmuRiz Elephant racing has oil lines that go up the pass-... Oct 14 2021, 10:59 AM
mepstein Elephant racing makes a kit that sends the lines u... Oct 14 2021, 11:02 AM
burton73 The reason to do it in the left side of car is tha... Oct 14 2021, 11:24 AM
Tdskip Thanks gentlemen, super helpful as always! Oct 14 2021, 11:25 AM
mepstein On my current 3.2 conversion, I have one line on t... Oct 14 2021, 12:05 PM
burton73 example of flex SS on a six, my six
Bob B Oct 14 2021, 01:37 PM
Tdskip Thanks for the additional ideas and documentation,... Oct 14 2021, 02:54 PM
roblav1 Stainless covered will last longer than OE hoses. ... Oct 14 2021, 03:02 PM
lesorubcheek One question for those who have ran their oil line... Oct 14 2021, 05:16 PM
roblav1 I dumped my charcoal lines. Running PMO carbs, so... Oct 14 2021, 09:02 PM
Tdskip All good Dan, if a thread helps someone take care ... Oct 15 2021, 07:44 AM
lesorubcheek
I dumped my charcoal lines. Running PMO carbs, s... Oct 15 2021, 12:18 PM
RiqueMar I too ran my lines on the passenger-side exterior,... Oct 15 2021, 12:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:34 AM |
