Can a CHT sensor go intermittently wonky? |
Robson51 |
Oct 14 2021, 01:32 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
I was watching Dr 914s walkaround of a D Jet 2.0 motor, and he makes a comment that the Cylinder Head Temp sensor causes a lot of problems, and can get wonky.
Is it possible for one to test out fine (2750 ohms) and then act bad? I have a strange syndrome where the car was running fine, but developed a rich syndrome very suddenly. Haven't had a chance to check it again, but it was almost new. TIA Rob |
76-914 |
Oct 14 2021, 03:51 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Might check the CHT wire to the ECU also. Do you have a known good MAP to cross check? Or carry an ohm meter to check the sensor output next time it gives up the Ghost. These type headaches are why I converted to water cooled. (IMG:style_emoticons/default/headbang.gif) GL
Superhawk996 |
Oct 14 2021, 04:32 PM
914 Guru Group: Members Posts: 5,880 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
These type headaches are why I converted to water cooled. (IMG:style_emoticons/default/headbang.gif) GL I gave up water pumpers due to coolant leakage. (IMG:style_emoticons/default/splat.gif) (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:07 PM |
