> GB up Fresh air screen and seal Yes WCR $20 coupon works on these, Grills ONLY at $12, with seal $24.99 for both Active til Nov 10th
Mikey914
post Sep 22 2021, 09:25 AM
Post #21
The rubber man
We have been casting these by hand for some time as they are needed. We have finally stepped up to high volume tooling and you can benefit for that.
The grills are an important part of keeping larger debris items out of your airbox. They were a late car item but can be retrofitted into the early cars. You may not even notice that you have this as many were painted over as removing the airbox is a pain, and most body shops don’t want to even think about it. May are painted over. As I mentioned these were hand cast, that meant that we had to go through and clean up the flash on these in the center “grill area” this required a lot of time.
These are “correct” for cars 1973-76 model years starting with VIN #24929. This set can be used for any model year as the grille only requires the top seal for backdating.
We had been selling these at $25 a pop as there was a lot of labor in them. Making this jump in tooling makes a better quality part and we can reduce the cost of what we can sell them at. The GB price on these The seal me make is a silicone seal that you can use glycerin to help slide in place. The OEM seals are a very small and hard to keep seated seal that caused me lots of frustration, so I made the larger seal that is easier to hold in place and provides a water tight seal.
Ian has even done up a great thread with a how to - https://youtu.be/Uhs6pedBOXM
You may not need it now but the now you have the ability to save a good chunk of change.
We are just finishing up these and they will be ready in about 14 days.
maf914
post Oct 22 2021, 12:56 PM
Post #22
Not a Guru!
I’ll take a set. Thanks, Mark.
Mikey914   GB up Fresh air screen and seal Yes WCR $20 coupon works on these   Sep 22 2021, 09:25 AM
NARP74   Probably on my list and I don't even know it y...   Sep 22 2021, 10:53 AM
Steve   I will take a set. I might need it someday...   Sep 22 2021, 11:11 AM
ndfrigi   1 set for me Mark.   Sep 22 2021, 11:18 AM
Mikey914   Figured that since there were a few threads poppin...   Sep 22 2021, 02:03 PM
Chris H.   Need one for sure!   Sep 22 2021, 03:38 PM
Front yard mechanic   Fresh off the grill for me :joesharp:   Sep 22 2021, 03:46 PM
PCH   Please count me in.   Sep 22 2021, 06:50 PM
914Sixer   I am in for one set of screen and seal.   Sep 22 2021, 08:16 PM
DC_neun_vierzehn   In for one screen and seal.   Sep 22 2021, 08:29 PM
914xr75   One screen and seal please.   Sep 23 2021, 06:33 AM
914e   I will take a grill and seal just to have on hand.   Sep 23 2021, 12:33 PM
808 WRX   I'm in for one set, maybe two :beer2:   Sep 23 2021, 02:04 PM
racer914   I will take a grill and seal set.   Sep 23 2021, 02:22 PM
davep   I would be looking for 2 sets.   Sep 23 2021, 08:00 PM
PaulFV8   I’m in for two sets please   Sep 23 2021, 08:41 PM
bob164   I'm in for a set.   Sep 24 2021, 07:37 AM
Montreal914   In for a set! Thank you! :)   Sep 24 2021, 10:33 AM
HansJan   Do all 914's have these? If so, I need a set.....   Sep 24 2021, 08:11 PM
Mikey914   Do all 914's have these? If so, I need a set....   Sep 25 2021, 04:33 AM
Mikey914   Pm's going out later this week   Oct 5 2021, 10:15 AM
Rick986   1 set please, Mark. Thanks!   Oct 5 2021, 01:24 PM
74K914   1 Set, thanks   Oct 8 2021, 03:20 PM
Mikey914   The GB is open on these and is available to all th...   Oct 20 2021, 11:39 AM
Root_Werks   I have so many unopened boxes from 914Rubber, I ho...   Oct 20 2021, 01:56 PM
Mikey914   If you bought an airbox kit you may have added thi...   Oct 20 2021, 09:59 PM
dyw914   I'm interested in a set. Thanks.   Oct 20 2021, 11:19 PM
autopro   I need just the grille as I already have the seal ...   Oct 21 2021, 08:57 AM
maf914   I’ll take a set. Thanks, Mark.   Oct 22 2021, 12:56 PM
Mikey914   PMs sent to all so far   Oct 23 2021, 08:35 AM
pete-stevers   Mikey! I will take two!   Oct 24 2021, 04:06 PM
- Lo-Fi Version Time is now: 16th June 2024 - 09:54 PM
