@#$%ing Dimmer Relay Tried to Kill Me |
bbrock |
Oct 21 2021, 09:59 AM
Two weeks ago I was coming home after dark at the end of a long 250 mile round trip through SW Montana for work. [Side note: if you pull up to a Montana rancher's house in a 914, he WILL get a kick out of it.] I noticed my lights were occasionally having trouble switching between dim and bright which required a double pull on he switch, but it wasn't consistent. I made a note to myself to look into it. I then crested a fairly remote and very dark mountain pass and dimmed my lights for an oncoming car. Then as I headed down the back side at 70+ mph into a sweeper on the descent, I tugged the switch to go back to brights. Instead of brights, I got total blackness... on a pitch black night in the middle of a curve on a remote mountain pass at high speed (IMG:style_emoticons/default/yikes.gif) I hit the brakes to scrub speed while feeling for the shoulder and flicking that dimmer switch with furry. After a half dozen tugs, the brights popped on. [side question: anyone know how to clean shit out of brick weave vinyl? (IMG:style_emoticons/default/blink.gif) ] Needless to say, I was not happy.
I finally got a chance to dig into the problem and started with the relay. This is not a 50 year old part. It was purchased new from Pelican less than a year ago as part of my bare metal restoration, and has seen less than 5 hours of service. Popping the cover off quickly revealed what shit build quality these new relays are despite being rather spendy. The relay pulls a thin metal finger into a 2-part (plastic and brass) rocker mechanism with two valleys and a splitter tooth between. Each cycle of the relay is supposed to position the splitter so the finger slides into the other valley on the next cycle. But the build tolerances were crap and there was so much float in the relay plate that the metal finger didn't line up consistently with the splitters. Often it wouldn't switch positions and sometimes it would miss the brass part of the splitter completely and get hung up on the plastic. When that happens, it's lights out! I was able to use a pair of needle nose pliers to squeeze the notches that guide the relay plate closed a little more to reduce the slop in the plate travel, and bend the tang holding the metal finger so it consistently engaged the brass splitter. After that, I was able to reliably cycle between bright and dim with no blackouts. The only question I have is if there are new replacements that are good quality and reliable. I think I paid $40 for this one and it tried to kill me. Most importantly, I wanted to warn people to beware of faulty dimmers. A jinky dimmer relay can go from just annoying to potentially deadly very fast! |
barefoot |
Oct 23 2021, 07:08 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Is there a solid state relay that can replace the OEM ????
Lo-Fi Version | Time is now: 4th June 2024 - 10:34 PM |
