VDO oil pressure gauge, The gauge is stuck and so am I |
NARP74 |
Oct 24 2021, 08:04 PM
Senior Member Group: Members Posts: 1,075 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Have a VDO oil sender and pressure and temp gauges in the car when I bought it. They were both flakey. Decided it was a ground due to the sender bouncing around. Got that fixed temporarily, kludge, bodge, hack, and one started working. Was poking around and now the pressure gauge gets pegged as soon as I turn the key. I have to thump it to get it to return to zero. Is it the sender, the gauge or something else?
speed metal army |
Oct 25 2021, 07:29 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
If the gauge is grounding out, it will peg. Check to see that the signal wire is all good. You didnt daisy the signal off the idiot light did you? That will also do it.
NARP74 |
Oct 25 2021, 08:12 PM
If the gauge is grounding out, it will peg. Check to see that the signal wire is all good. You didnt daisy the signal off the idiot light did you? That will also do it. It was working, then stopped after I fixed the grounding for the sender. Gave up the ghost I guess. My wires all checked out and the gauges are ok too. No daisy chain, all new wires in a home run. I'll look for a sender tomorrow, then the light and the 2 gauges will work again instead of 2 of the 3 working. |
Lo-Fi Version | Time is now: 18th June 2024 - 04:20 AM |
