Best way to run a power wire..., ...from battery to console area? |
Rick986 |
Oct 27 2021, 03:08 PM
0-60 in 14 seconds! Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest |
Upgraded my speakers to Infinity Kappa 62IX mounted in 914 Rubber's pods. Massive upgrade in sound...but would still like a little more low-end "punch". I'm going to install a Recoil SL1708 subwoofer inside the console cavity (no holes in console, it just sits inside there!) and need to run a power wire.
What is the "easiest" way to get this through the car? Sorry if this is a silly question but I haven't messed with any electrical stuff yet and can't see how the current wires from the battery enter the vehicle. Seems like they come in behind the seats so maybe there's some kind of "sealed" pass-thru through the firewall? My lift is not in yet so I have somewhat limited access to the bottom of the car and would rather not take the seats out if I don't have to! Thanks! - Rick |
Puebloswatcop |
Oct 27 2021, 03:29 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Upgraded my speakers to Infinity Kappa 62IX mounted in 914 Rubber's pods. Massive upgrade in sound...but would still like a little more low-end "punch". I'm going to install a Recoil SL1708 subwoofer inside the console cavity (no holes in console, it just sits inside there!) and need to run a power wire. What is the "easiest" way to get this through the car? Sorry if this is a silly question but I haven't messed with any electrical stuff yet and can't see how the current wires from the battery enter the vehicle. Seems like they come in behind the seats so maybe there's some kind of "sealed" pass-thru through the firewall? My lift is not in yet so I have somewhat limited access to the bottom of the car and would rather not take the seats out if I don't have to! Thanks! - Rick Hi Rick, The bad news is that the power supply wires go into the interior of the car through the main wiring harness through the snorkle tube and then run along the tunnel up under the dash. If you are looking to run a power wire to the sub woofer, I would look at running off of the fuse panel so that it is a protected circuit. Kevin |
Lo-Fi Version | Time is now: 29th May 2024 - 02:58 AM |
