Clutch shafts |
Clutch shafts |
DLewis |
Oct 28 2021, 08:33 AM
Member Group: Members Posts: 63 Joined: 3-December 04 From: Poway, CA (was SF Bay area) Member No.: 3,212 Region Association: None |
I am rebuilding a pedal cluster for a member on the Pelican site with a 911.
He sent two clusters to make one and they had two different shafts. They are the same overall length. The one that is not straight on the end is from the 914. I think the straight one is from a 911 but I don't know what year. Also when you line up the holes where the roll pin goes they are offset slightly. So my questions are: Which one should I use If I go with the 914 one will it work in a 911 Thanks, Dean |
rudedude |
Oct 28 2021, 04:04 PM
Senior Member Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I just did this on a 72 911 and it has the straight one with the bushing. I wonder if it is due to the 915 transmission
Lo-Fi Version | Time is now: 9th June 2024 - 03:59 PM |
