Output flange bolt, My stuff up!! |
DaveO90s4 |
Oct 30 2021, 05:44 AM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Hi all. I misread the torque spec for the “drive flange expansion bolt” and over torqued it. Have now removed that bolt without it snapping. Since this bolt is really just holding the splined drive flange on, I’m inclined to think that an ‘ordinary’ M10x1.5 bolt of the oem hardness (8.8) will do the job as a replacement - unless i can get a new oem one promptly and cheaply
Any compelling views to the contrary? Thanks Dave |
Luke M |
Oct 30 2021, 05:58 AM
Senior Member Group: Members Posts: 1,377 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Hi all. I misread the torque spec for the “drive flange expansion bolt” and over torqued it. Have now removed that bolt without it snapping. Since this bolt is really just holding the splined drive flange on, I’m inclined to think that an ‘ordinary’ M10x1.5 bolt of the oem hardness (8.8) will do the job as a replacement - unless i can get a new oem one promptly and cheaply Any compelling views to the contrary? Thanks Dave Here you go. Page 25 has the torque specs. Those bolts are the expandable type and prob should not be reuse. I haven't tried to find any nos bolts so I have used old ones with no issues. http://p914-6info.net/PDFs/Group%203%20transmission.pdf |
DaveO90s4 |
Oct 30 2021, 06:30 AM
Hi Luke thanks for your reply. Yes, i have the torque specs - just read the wrong item and overtorqued it, stopping when i felt it begin to yield. Since I felt it yield I’m very reluctant to use it again. So am thinking about options.
Any more views, opinions, suggestions etc much appreciated. Cheers Dave |
Lo-Fi Version | Time is now: 9th June 2024 - 11:44 PM |
