VDO parts, cup type diffusers |
jims914 |
Nov 4 2021, 06:45 PM
Member Group: Members Posts: 125 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region |
Looking for a source for VDO gauge part.
Looking for the cup or hat type red, green, amber diffusers. Tried Helier and Palo Alto. Thanks for any response. |
FlacaProductions |
Nov 4 2021, 07:14 PM
Senior Member Group: Members Posts: 1,616 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
That's a tough get. It's either rescue them from dead instruments, make your own or ask a friend who works in plastics(!) to do some for you - or switch out to just flat acrylic which is not OEM appearance but is very easy to procure from amazon, etc. You would probably want to "scuff" them up a little bit with some high grit sandpaper to give them a frosted look.
I had a fellow lister here pour some acrylic ones for me after pulling a mold from a sacrificial one but the final finish work was pretty time-consuming for anything more than just a couple - sanding them into shape and proper thickness and then ending up with the right 'frosted' finish. on mine, i also replaced the usually-white one with a red for visual continuity - and i put an LED behind it as an additional indicator for another function. they white lenses can be VERY brittle - but so can the red and green ones. I think mine turned out great but i think if i were to do it again - and originally i had designs on maybe having these done in mass quantities - i'd just switch over to some 1 or 2mm flat, colored acrylic stock and glue them in. UNLESS someone like @mikey914 and 914rubber would be able to do this in quantity at a reasonable cost? I've wondered where places like North Hollywood and Palo Alto get their stuff...I suspect they have a stash that they are raiding.... |
Lo-Fi Version | Time is now: 9th June 2024 - 02:26 PM |
