VDO parts, cup type diffusers |
jims914 |
Nov 4 2021, 06:45 PM
Member Group: Members Posts: 125 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region |
Looking for a source for VDO gauge part.
Looking for the cup or hat type red, green, amber diffusers. Tried Helier and Palo Alto. Thanks for any response. |
Mikey914 |
Nov 4 2021, 08:48 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I do have the plastic sheet that could be used. I tried it and wasn't too satisfied with the look.
The key is mass quantities. I to can cast in small quantities, but as you may have noted the unit cost can add up. May be worth doing a Group buy on a "set". To do this Id be looking at 200 sets at $5-6 a set. That wouldn't even cover tooling but Id be game if there was even close to that much interest. Mark |
jims914 |
Nov 4 2021, 10:14 PM
I do have the plastic sheet that could be used. I tried it and wasn't too satisfied with the look. The key is mass quantities. I to can cast in small quantities, but as you may have noted the unit cost can add up. May be worth doing a Group buy on a "set". To do this Id be looking at 200 sets at $5-6 a set. That wouldn't even cover tooling but Id be game if there was even close to that much interest. Mark Hello Mark, Looking into the colors of acrylic plexiglass lucite to machining some up. For the fuel-temp gauge combo. looking at red, green, amber. I think there is a need for it. The gauge soroses will not supply them. Thanks again Jim |
Lo-Fi Version | Time is now: 9th June 2024 - 05:27 PM |
