Trying to install the fresh air box, Having troubles - Any tips? |
Doug Leggins |
Jan 5 2005, 09:18 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I've got the fresh air box and fan all cleaned up, painted and ready to install. I cannot get the bolt in the driver's side cowl bracket. I just can't get the box in a position that will allow for the threaded insert in the box to line up with the hole in bracket. With enough persuasion I was able to get the passenger side bolt started but no go on the driver's side so far. Any suggestions?
I seem to be having some interference between the wiper motor and the pad on the back side of the air box fan. It looks to me that the pad is there to keep the wiper motor and fan housing from rattling. Should the fan housing pad make contact with the wiper motor creating a snug fit? Attached image(s) |
agrump |
Jan 6 2005, 09:51 AM
Member Group: Members Posts: 141 Joined: 13-November 04 From: Atlanta, GA Member No.: 3,103 |
I did mine a couple of weeks ago. The gasket was binding on the lip as mentioned. I found it easier to install the box at a slight angle. The drivers side went in first and I loosely put in the bolt before getting the passenger side in. To get the clip on the cable secure I found that a medical forceps with a curved edge worked great for snapping it in place.
Lo-Fi Version | Time is now: 23rd May 2024 - 01:49 AM |
