Antenna, Odometer , Cushion, repair needed |
Stef914 |
Nov 9 2021, 12:05 AM
Member Group: Members Posts: 70 Joined: 21-July 21 From: Los Angeles Member No.: 25,745 Region Association: Southern California |
Hi there,
I've got some newbie / rookie questions for you all (IMG:style_emoticons/default/smile.gif) 1- I have the antenna key but I can't figure out how to lift it... I can twist it around but it still remains down ...ideas ? 2- my odometer & trippometer are not working. Was gonna pull the gauge out myself and send for repair, but before I do that is it easy to disconnect all the cable on the back without any tools ? ( if even doable to taking it apart this way ) 3- I was gonna replace the cushion seat but upon lifting it I notice a cable attached to it, ideas ? thanks S. |
barefoot |
Nov 9 2021, 06:36 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Hi there, I've got some newbie / rookie questions for you all (IMG:style_emoticons/default/smile.gif) 1- I have the antenna key but I can't figure out how to lift it... I can twist it around but it still remains down ...ideas ? 2- my odometer & trippometer are not working. Was gonna pull the gauge out myself and send for repair, but before I do that is it easy to disconnect all the cable on the back without any tools ? ( if even doable to taking it apart this way ) 3- I was gonna replace the cushion seat but upon lifting it I notice a cable attached to it, ideas ? thanks S. The speedo cable should be easy & the odo re-set cable will pull out of the speedo, if you're flexible enough to crawl up under the dash. If memory serves me i think you can dis-connect all this by pulling the speedo out toward the steering wheel. The wire going into the seat cushion is part of the dreaded seat belt interlock where you had to have the seatbelt connected if there was weight in the seat to start the engine. If you've dis-connected this feature, just cut that cable. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:03 PM |
