Engine lid fit |
Engine lid fit |
PCH |
Nov 8 2021, 02:54 PM
Member Group: Members Posts: 141 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
The engine lid on my 1971 doesn't seem to fit correctly. See the picture below.
Note the lid seems to be too low in front by the rear window. The rubber seal is 914Rubber. I don't see a way to close the gap other than bending or rewelding the brackets. It looks like the brackets came like that from the factory. What am I missing? Where there different lids on different model years? Anyone have a trick/idea on how to close the gap.? Thanks, Peter Attached thumbnail(s) |
rhodyguy |
Nov 9 2021, 08:15 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Failing to catch the lid while opening reefs on the brackets when the lid flys up. Check for cracks or rewelds. I slotted the the holes on the lid arms all the way through with my grinder. Just start the bolts and the arms slide in to place. Makes the install ordeal a simple one person job. No back and forth dance. The arm modification is only seen when the lid is removed.
rgalla9146 |
Nov 9 2021, 05:59 PM
Advanced Member Group: Members Posts: 4,561 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Failing to catch the lid while opening reefs on the brackets when the lid flys up. Check for cracks or rewelds. I slotted the the holes on the lid arms all the way through with my grinder. Just start the bolts and the arms slide in to place. Makes the install ordeal a simple one person job. No back and forth dance. The arm modification is only seen when the lid is removed. (IMG:style_emoticons/default/agree.gif) did the same on my orange stocker. forgot to do it on my modified car.....DOH ! |
Lo-Fi Version | Time is now: 1st June 2024 - 05:06 AM |
