Idle bleed screw on 73 2.0, Does it close? |
emerygt350 |
Nov 19 2021, 02:02 PM
Advanced Member Group: Members Posts: 2,132 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Wondering if the idle screw should be capable of completely closing off the air bleed. I noticed today that when mine is screwed All the way in it still allows air through the channel. If I put my thumb over the channel the idle drops another 200 rpm.
iankarr |
Nov 19 2021, 06:00 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
When I fully close my bleed screw the engine dies.
JeffBowlsby |
Nov 19 2021, 06:28 PM
914 Wiring Harnesses Group: Members Posts: 8,525 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
When I fully close my bleed screw the engine dies. (IMG:style_emoticons/default/agree.gif) Thats the way it should be, the engine should die with no intake aire source. Otherwise you have a free air leak somewhere in the intake that overrides the air bleed screw function. |
rjames |
Nov 19 2021, 08:16 PM
I'm made of metal Group: Members Posts: 3,948 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
When I fully close my bleed screw the engine dies. (IMG:style_emoticons/default/agree.gif) Thats the way it should be, the engine should die with no intake aire source. Otherwise you have a free air leak somewhere in the intake that overrides the air bleed screw function. The leak is from the bleed screw port. For some at least, screwing it in all the way doesn’t fully seal it. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:11 AM |
