Venting a little frustration, Previous owner was a moron. Fuel line foolishness. |
LefthandRev |
Nov 20 2021, 01:28 PM
Member Group: Members Posts: 76 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
To keep it short, I've owned this current 914 since August or so. Since then, I've chased down, repaired, replaced, and otherwise fixed all sorts of idiotic things the previous owner did (or failed to do) to this car.
I've been smelling fuel over the last few days. And before you admonish me for not doing this sooner, I had given a cursory glance at the fuel line in the past and saw no leaks... I should have done a better job. Dummy before me kinked the fuel line and did a piss poor job of routing it. See pics below for before and after. It was leaking out of the hard line. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1637436525.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1637436526.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1637436526.3.jpg) Headed out now to get a new filter and better hose clamps. |
914werke |
Nov 20 2021, 04:02 PM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Yikes. (IMG:style_emoticons/default/blink.gif) I only see one line so must be converted to carbs?
Do yourself a favor, dont use serrated worm drive clamps!! Use the proper (fuel injection style) clamps ~ |
Justinp71 |
Nov 22 2021, 10:27 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Yikes. (IMG:style_emoticons/default/blink.gif) I only see one line so must be converted to carbs? Do yourself a favor, dont use serrated worm drive clamps!! Use the proper (fuel injection style) clamps ~ Good tip. Is this because the serrates can cut the fuel line when clamping tight? |
LefthandRev |
Nov 22 2021, 12:22 PM
Yikes. (IMG:style_emoticons/default/blink.gif) I only see one line so must be converted to carbs? Do yourself a favor, dont use serrated worm drive clamps!! Use the proper (fuel injection style) clamps ~ Good tip. Is this because the serrates can cut the fuel line when clamping tight? Thanks for that tip. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:04 PM |
