> Swiveling shift lever
emerygt350
post Nov 23 2021, 08:13 AM
My stick swivels clockwise if pushed hard trying to got into reverse or first. If you swivel it back it kinda holds into a better position. If you are real nice to it this doesn't happen. Suggestions? It moves maybe an inch to the left. Maybe 15 degrees.
Shivers
post Nov 23 2021, 08:43 AM
If I'm reading this correctly, the rod is held into the ball at the bottom with adhesive. Epoxy. I had to separate the pieces to install a short shift. Heat the lower piece with a torch and it will come apart. Clean both pieces and JB weld together.
Superhawk996
post Nov 23 2021, 09:21 AM
QUOTE(Shivers @ Nov 23 2021, 09:43 AM) *
Ha . . . Learned something new today. I had assumed the ball was machined and a press fit to shift lever.
Just cleaned grease off a shift lever and sure enough, it looks like some adhesive is there at the top of the ball.
- Lo-Fi Version Time is now: 16th November 2026 - 05:43 AM
