Throttle Body Rebuild Question |
rbzymek |
Nov 21 2021, 03:55 PM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
Looking for a source to repair a sticking 2.1L Vanagon throttle body. So far my PM's to members have been unsuccessful. I am interested in new bearings and seals. Any help is appreciated.
Bartlett 914 |
Nov 23 2021, 12:34 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
TJB/914 |
Nov 23 2021, 03:33 PM
Mid-Engn. Group: Members Posts: 4,334 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Looking for a source to repair a sticking 2.1L Vanagon throttle body. So far my PM's to members have been unsuccessful. I am interested in new bearings and seals. Any help is appreciated. Hi Ray I sent you a PM. I still do these repairs if interested Mark, Tell us more about your "Throttle Body" restoration/repairs. (IMG:style_emoticons/default/popcorn[1].gif) I am interested. Tom MI |
Bartlett 914 |
Nov 23 2021, 04:11 PM
Looking for a source to repair a sticking 2.1L Vanagon throttle body. So far my PM's to members have been unsuccessful. I am interested in new bearings and seals. Any help is appreciated. Hi Ray I sent you a PM. I still do these repairs if interested Mark, Tell us more about your "Throttle Body" restoration/repairs. (IMG:style_emoticons/default/popcorn[1].gif) I am interested. Tom MI I disassemble and clean everything. The body is normally worn where the throttle shaft goes through. This causes the throttle plate to stick when closed. This causes a jump when the throttle is first depressed. I have built fixtures that hold the body in position and I precision machine for a new bearing. This is a little more complicated that it may seem in order to have both sides in proper alignment. The bearings must be cut to size and reamed after installation. I currently only clean the parts. I do not plate the parts. I hope to so in the future but not currently. I have done quite a few of these and no complaints. Occasionally the bore of the throttle body is damaged by the sticking plate. I open the throttle body bore in these cases and I make new throttle plates for a proper fit. These plates are a little tricky as they are not actually round. I have all this worked out, Thanks for your interest |
TJB/914 |
Nov 24 2021, 12:50 PM
Looking for a source to repair a sticking 2.1L Vanagon throttle body. So far my PM's to members have been unsuccessful. I am interested in new bearings and seals. Any help is appreciated. Hi Ray I sent you a PM. I still do these repairs if interested Mark, Tell us more about your "Throttle Body" restoration/repairs. (IMG:style_emoticons/default/popcorn[1].gif) I am interested. Tom MI I disassemble and clean everything. The body is normally worn where the throttle shaft goes through. This causes the throttle plate to stick when closed. This causes a jump when the throttle is first depressed. I have built fixtures that hold the body in position and I precision machine for a new bearing. This is a little more complicated that it may seem in order to have both sides in proper alignment. The bearings must be cut to size and reamed after installation. I currently only clean the parts. I do not plate the parts. I hope to so in the future but not currently. I have done quite a few of these and no complaints. Occasionally the bore of the throttle body is damaged by the sticking plate. I open the throttle body bore in these cases and I make new throttle plates for a proper fit. These plates are a little tricky as they are not actually round. I have all this worked out, Thanks for your interest Mark, Sound good (IMG:style_emoticons/default/smilie_pokal.gif) I'll send you a PM next week for instructions where to send for this repair. Good time to send during winter storage. Any budge guess-estimate low to high $__ Amount? Tom In MI g |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:06 AM |
