| Tdskip |
Nov 24 2021, 07:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
First of all best wishes for a great Thanksgiving tomorrow, and for those in the rest of the world forgive us if we’re a bit sluggish on our keyboards tomorrow due to food induced comas.
I’m trying to help a friend out with a new to him 914 that came with a vague description of transmission problems. The gearbox was super sloppy so we got the car in the air and I explained to him how important it was that it had fresh in correct bushings and set screws in the linkage so we took it all apart and put new parts in and adjusted the shift pattern. The good news is that the gearbox was transformed in the shift action, just as you would expect it to be, and we can get reversed, first, second, third cleanly but fourth and fifth keep popping out of gear. You can find the slot for fourth and fifth but it just won’t stay in gear gear. Reverse through 3rd are in the normal place with the gear lever, so I don’t think I’ve got the rod misaligned. I checked the clutch tube and I don’t think we’re getting movement on that, so I am getting that sick to my stomach feeling that it’s an internal to the box issue.. Any ideas or suggestions on something that I may be missing? |
| 914Mels |
Nov 24 2021, 09:01 PM
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Happy Thanksgiving! For what its worth, I'd have your friend work the shifter while you watch the shift linkage at the trans with the motor off and compare the movements between 2-3 and 4-5. 4th and 5th usually get the least amount of wear so hopefully it's still an adjustment issue in the linkage.
Tdskip Trying to pay it forward – friends 914 is popping out fourth and fifth gear Nov 24 2021, 07:04 PM
Shivers Tail shift? Nov 24 2021, 07:15 PM
Mikey914 Either the cone screw is backed out or more likely... Nov 24 2021, 07:21 PM
Tdskip Hi guys, thanks for the responses.
Side shifter.
... Nov 24 2021, 08:12 PM
NARP74 Motor mounts, trans mounts? Nov 24 2021, 09:32 PM
Mikey914 If the knuckle is good, it must just be out of adj... Nov 24 2021, 10:08 PM
Tdskip Thanks for the suggestions, will try again! Nov 25 2021, 12:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th November 2026 - 07:32 PM |
