Need a measurment, for front anti-sway droplinks |
Dave-O |
Jan 5 2005, 02:12 PM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
Hey all,
This is for my fabricated front sway bar. What is the range of adjustability of the standard adjustable drop links (welt, tarret, smart, etc.) from the center of one hole to the center of the other hole? Another quick question... How does this range work for slightly lowered 914's? Should they be any shorter/longer? I'm having some parts machined and i don't have my 914 around to measure. Gotta love the campus machine shop, they're doing the work for free! thanks in advance, David |
ottox914 |
Jan 6 2005, 06:00 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
When you're ready...
In an attempt to make a better mousetrap, I couldn't tell for sure if the drop link was height adjustable or not. I know you noted using stock measurements, but to make that drop link adjustable would be great for lowered cars or for use in corner balancing with the driver weight balasted in the car, to set a no-bind length for the drops. Just a thought in case you hadn't covered that base yet. |
Lo-Fi Version | Time is now: 12th June 2024 - 08:21 PM |
