| emerygt350 |
Nov 23 2021, 08:13 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,829 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
My stick swivels clockwise if pushed hard trying to got into reverse or first. If you swivel it back it kinda holds into a better position. If you are real nice to it this doesn't happen. Suggestions? It moves maybe an inch to the left. Maybe 15 degrees.
| 930cabman |
Nov 24 2021, 06:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,883 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Slightly off topic, ..... has anyone reduced the spring tension required to push the shift lever into the R - 1 gate?
| toolguy |
Nov 25 2021, 09:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
| 930cabman |
Nov 25 2021, 05:22 PM
Slightly off topic, ..... has anyone reduced the spring tension required to push the shift lever into the R - 1 gate? You risk going into 1st when doing an aggressive 4th to 3rd downshift Don't ask how i know but it will happen. . . Thanks. I have been considering this for a while, and I personally never "aggressively shift" any of my sporting machines. Even when new, these gearboxes required a soft touch. just my .02 |
| ChrisFoley |
Nov 25 2021, 07:05 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,035 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Slightly off topic, ..... has anyone reduced the spring tension required to push the shift lever into the R - 1 gate? You risk going into 1st when doing an aggressive 4th to 3rd downshift Don't ask how i know but it will happen. . . Thanks. I have been considering this for a while, and I personally never "aggressively shift" any of my sporting machines. Even when new, these gearboxes required a soft touch. just my .02 Rennshift is spring-loaded both left and right, and the spring pressure can be adjusted to your preference. |
emerygt350 Swiveling shift lever Nov 23 2021, 08:13 AM
Superhawk996 Not sure I fully understand (picture??) but, if we... Nov 23 2021, 08:30 AM
Shivers If I'm reading this correctly, the rod is held... Nov 23 2021, 08:43 AM
Superhawk996
If I'm reading this correctly, the rod is hel... Nov 23 2021, 09:21 AM
emerygt350 Now I am regretting the console ... Nov 23 2021, 09:32 AM
ChrisFoley Guys with long legs benefit from breaking the epox... Nov 23 2021, 11:33 AM
emerygt350
Guys with long legs benefit from breaking the epo... Nov 23 2021, 02:16 PM
Tdskip Maybe I miss reading this but if the shift rod is ... Nov 24 2021, 07:01 PM
ChrisFoley
Maybe I miss reading this but if the shift rod is... Nov 25 2021, 07:34 AM
emerygt350 If I pull up the console and remove that plate hol... Nov 25 2021, 09:40 AM
emerygt350 Did a little Sunday morning stick work. Went quit... Dec 5 2021, 11:31 AM
Superhawk996
Did a little Sunday morning stick work. Went qui... Dec 5 2021, 12:47 PM
Shivers :cheer: :cheer: :cheer: Dec 5 2021, 02:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th November 2026 - 05:43 AM |
