| DC_neun_vierzehn |
Nov 28 2021, 06:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 699 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I have a '73 2.0 (the fuel pump was relocated to the front by the PO).
Lately I've been hearing some noises coming from behind dash/frunk area. It sounds like a pulsating strained noise (almost sounds like a duck). The noise isn't constant. I don't recall hearing it when I start up, but I definitely hear it when I pull up to a red light or get off the highway. I feel like I've narrowed it down to the fuel pump because there's nothing else on when I hear the noise (fresh air box or heat fan in rear). My question(s): Do fuel pumps make noises like this before they're about to die? Could it be something else? Here are some pics ... Attached thumbnail(s) |
| 914Sixer |
Nov 28 2021, 06:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,613 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Make sure your hoses are not bent or kinked. Is your fuel filter and tank filters good? Please change out the hose clamp in the 2nd picture to same style as in last picture. ONLY use band clamp, NEVER worm gear clamp on fuel line as it cuts into the hose.
DC_neun_vierzehn Fuel pump making noises (I think) Nov 28 2021, 06:16 PM
DC_neun_vierzehn RE: Fuel pump making noises (I think) Nov 28 2021, 06:17 PM
DC_neun_vierzehn RE: Fuel pump making noises (I think) Nov 28 2021, 06:18 PM
DC_neun_vierzehn
Make sure your hoses are not bent or kinked. Is ... Nov 30 2021, 03:51 PM
914Sixer Yep, most auto parts should have them. Not seeing... Nov 30 2021, 06:54 PM
DC_neun_vierzehn
Yep, most auto parts should have them. Not seein... Nov 30 2021, 09:56 PM
Front yard mechanic I have the same or very similar pump. I hate it ... Nov 30 2021, 09:32 PM
DC_neun_vierzehn
I have the same or very similar pump. I hate it ... Nov 30 2021, 09:57 PM
ClayPerrine
[quote name='Front yard mechanic' post='2963841' ... Dec 3 2021, 02:57 PM
DC_neun_vierzehn I have a hard time believing the duck noises from ... Dec 2 2021, 08:11 PM
Shivers
I have a hard time believing the duck noises from... Dec 2 2021, 09:29 PM
914werke Check for blockage on both the supply & return... Dec 2 2021, 09:02 PM
DC_neun_vierzehn Thanks for the detailed info, Clay! Dec 3 2021, 04:56 PM
DC_neun_vierzehn I found the Airtex E8445 pump on Amazon for ... Dec 3 2021, 05:02 PM
ClayPerrine Just an additional thought...
I always put a fuel... Dec 4 2021, 09:03 AM
DC_neun_vierzehn
I always put a fue... Dec 10 2021, 09:08 AM
ClayPerrine
[quote name='ClayPerrine' post='2964612' date='De... Dec 10 2021, 10:10 AM
Porschef I realize I’m a bit late here but I got a Bosch ... Dec 10 2021, 01:14 PM
Porschef I realize I’m a bit late here but I got a Bosch ... Dec 10 2021, 01:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 04:08 AM |
