| dr914@autoatlanta.com |
Nov 30 2021, 11:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,255 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Read the owners manual thoroughly purchase and read the 914 “tech tips 700” book thoroughly when starting cold, turn the key on and off four times before cranking, you will hear the fuel pump run and stop each time. This primes the pump and injects a bit of fuel for easy starting. this is for 2.0 models only, 1.7 and 1.8 are different If you do not hear the fuel pump run momentarily when first turning the key to the ON position, the car will not start, so do not try ALWAYS two point shift down or up. Meaning when you shift, hesitate momentarily between gears. NO SPEED SHiFTING When at a stop light you may find that you cannot get the 914 (or for that matter 66-71 911 or 912) in gear. Do not try to force it. Even if they are honking horns at you, just put the car in another gear and then back into first. In an extreme you may have to put it in another gear go forward a bit and then back into first. All 901 gearboxes are this way the 914 has a cable clutch, always make sure that the pedal is all of the way up and you can shake it about a half an inch. If the pedal is down and you can pull it up the clutch cable needs adjustment. If you leave it that way the car will begin to grind in first and reverse and will damage the gearbox Always check the oil when you fill up with REGULAR gasoline. let the car sit first and then push the dipstick all of the way down and twist to make sure it is all of the way down. If you check the oil when the engine is cold it will read too low. The engine uses 3.75 quarts of conventional oil with zinc in it, and the weight is 20w50 up where you live when you open the door from the outside support the latch over the lock cylinder with your thumb to make sure excessive force is not put on the flap part and avoiding breaking it off change the oil once a year, or every 3000 miles and clean the strainer basket at the same time periodically lubricate the rear trunk hinge bracket shoulder bolt where the hinge pivots when you close the rear trunk let it drop and then with the heal of your hand clip shut at the very rear where the reinforcement lies If you remove the battery make sure that there is a blanket covering the rear quarter and rear deck lid or it may drip acid and discolor the paint No slamming the doors or deck lids, everything is gentle with a 914 |
| sb914 |
Nov 30 2021, 01:38 PM
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,701 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California
most importantly! |
dr914@autoatlanta.com some tips I just wrote for a new 914 owner Nov 30 2021, 11:10 AM
flipb If it's a '74 and won't start, make su... Nov 30 2021, 11:28 AM
Jett
If it's a '74 and won't start, make s... Nov 30 2021, 01:03 PM
NARP74 From an editing standpoint, is the four key on off... Nov 30 2021, 11:35 AM
914Mels If your electrical system seems to be out after ge... Nov 30 2021, 11:35 AM
dakotaewing
most importantly!
Make sure you get the ... Nov 30 2021, 02:31 PM
Robarabian Don't try to reset the odometer to 0000 when d... Nov 30 2021, 01:52 PM
dr914@autoatlanta.com you guys are good, thank you. Just want to make s... Nov 30 2021, 03:26 PM
Betty How about: "Be prepared for people to come u... Nov 30 2021, 04:55 PM
wonkipop after you start it, stick your head in the engine ... Nov 30 2021, 05:42 PM
bkrantz Remember to adjust the valves frequently. They ar... Nov 30 2021, 09:48 PM
Jett Turn signal light working without the key in the i... Nov 30 2021, 10:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th November 2026 - 07:46 PM |
