123ignition install, kicking my butt |
IronHillRestorations |
Dec 7 2021, 01:26 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'm installing a 123ignition in a customer's 914-6 (conversion) and it's really kicking my butt. It's a 2.7 with PMO's, and as you probably know, distributor access is a PITA in a 914-6. Cutting an access hole in the firewall isn't an option.
I've never had this much trouble installing a distributor. I've done at least half a dozen distributor installs in a 914-6, a few 911's, and numerous 914-4's. I've confirmed TDC#1 with a scope in #1 (piston up, valves closed), and installed the distributor per the exceptionally generic instructions that came with the distributor. I've moved the distributor in roughly 1mm increments both directions about 20* and I can't get the engine to run. Some loud pops and bangs, but that's it. Any experienced advice would be appreciated! I like the concept of the 123ignition unit, but there's a few things about it that could stand improvement. The clips for the distributor cap are very flimsy for a new distributor in this price range and fit poorly. There were problems with the spring loaded center terminal of the cap right out of the box. There's no specific instructions for this engine. The US dealer, while a nice guy and good to return calls is not a mechanic and slim on tech support. It seems to me the problem is indexing the LED with the shutter while getting the rotor at #1 with the cap in the right orientation. I didn't think it would be this hard. Customer purchased the distributor on my recommendation, so I'm compelled to get it going. I've never had a car I couldn't get going, so this is frustrating. |
Gatornapper |
Dec 8 2021, 06:43 AM
Senior Member Group: Members Posts: 1,235 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Perry -
I can't help you and hope Phil's advice does the trick. But I want you to know that I am very encouraged to see that an experienced Wrench like you also runs into difficulties occasionally - ones that seem that they would be simple. As I know your knowledge and experience are not the problem. (IMG:style_emoticons/default/sunglasses.gif) And you are charting the way for me as I want to put a 123 in my 914 someday - tho my 050 is doing great. A bit disconcerting to hear about the cap clips and center electrode tho........ GN I'm installing a 123ignition in a customer's 914-6 (conversion) and it's really kicking my butt. It's a 2.7 with PMO's, and as you probably know, distributor access is a PITA in a 914-6. Cutting an access hole in the firewall isn't an option. I've never had this much trouble installing a distributor. I've done at least half a dozen distributor installs in a 914-6, a few 911's, and numerous 914-4's. I've confirmed TDC#1 with a scope in #1 (piston up, valves closed), and installed the distributor per the exceptionally generic instructions that came with the distributor. I've moved the distributor in roughly 1mm increments both directions about 20* and I can't get the engine to run. Some loud pops and bangs, but that's it. Any experienced advice would be appreciated! I like the concept of the 123ignition unit, but there's a few things about it that could stand improvement. The clips for the distributor cap are very flimsy for a new distributor in this price range and fit poorly. There were problems with the spring loaded center terminal of the cap right out of the box. There's no specific instructions for this engine. The US dealer, while a nice guy and good to return calls is not a mechanic and slim on tech support. It seems to me the problem is indexing the LED with the shutter while getting the rotor at #1 with the cap in the right orientation. I didn't think it would be this hard. Customer purchased the distributor on my recommendation, so I'm compelled to get it going. I've never had a car I couldn't get going, so this is frustrating. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:34 PM |
