Long, productive weekend... |
Lawrence |
May 27 2003, 09:27 AM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
Well, it certainly was a long weekend. I'm glad to get back to work, so I can get some rest. (IMG:style_emoticons/default/smile.gif)
I worked on the /6 this weekend with Pam's help. Accomplished: - Underside of floorboards scrubbed clean with drill and wire wheel. (IMG:style_emoticons/default/blink.gif) - Inside floorboards scraped all the tar and cleaned. - Painted top and bottom with POR-15. - Installed Bill Greenway's trunk shock kit. - Replaced speedo angle drive. - Rebuilt pedal cluster, painted with POR-15. (IMG:style_emoticons/default/beer.gif) - Painted pedal board. - Replaced bushings in 914/6 throttle linkage. - Replaced fuel lines with steel in center tunnel, cleaned under the gas tank. (IMG:style_emoticons/default/boldblue.gif) I found a few rust spots... So there's a bit of welding in my future. The bushings in the pedal cluster and throttle linkage were absolutely non-existent. Because of the new bushings, I had to readjust the clutch and throttle. They're still not perfect, but it's driveable. I was just too tired to screw with it anymore. After all this work, especially to the throttle and pedal cluster, the car drives completely differently. (IMG:style_emoticons/default/driving.gif) -Rusty |
Jeroen |
May 28 2003, 06:51 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:30 PM |
