Steering rack boot torn question |
rosenfe |
Jan 1 2022, 07:24 PM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
On my 74,one side of rack has torn boot . Is the only solution to replace rack?
Mikey914 |
Jan 2 2022, 11:56 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I was referring to the bolt / nut at 1:39. Installation would be just the reverse. DO check the tie rods. I have the complete assemblies if you need them. As well as the eye bolt rebuild kit if the rubber there is shot.
NARP74 |
Jan 2 2022, 12:33 PM
Senior Member Group: Members Posts: 1,074 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I was referring to the bolt / nut at 1:39. Installation would be just the reverse. DO check the tie rods. I have the complete assemblies if you need them. As well as the eye bolt rebuild kit if the rubber there is shot. I sense a business opportunity here @Mikey914 . On one of my other vehicles they make a retrofit kit with a split, glue-able boot, no disassembly or alignment required. Could put that on your long list of parts to make in the future. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:28 PM |
