| jkb081 |
Jan 9 2022, 07:23 PM
Member ![]() ![]() Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
| Mikey914 |
Jan 9 2022, 07:35 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
It should be plastic lnot the metal one.
| jkb081 |
Jan 9 2022, 08:56 PM
It should be plastic lnot the metal one. OK, thanks. I thought the 1.7 was metal, the 1.8 was plastic, and the 2-L was the big square metal one. Im not sure if I have an early or late 73. The numbers that are supposed to be in the front trunk, and in the rear trunk are missing. Both trunks have been sprayed with "bed liner" I cannot find/see the engine number either. I have looked at the area where it is supposed to be, but cannot see anything. |
| JamesM |
Jan 10 2022, 08:22 AM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,320 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
It should be plastic lnot the metal one. OK, thanks. I thought the 1.7 was metal, the 1.8 was plastic, and the 2-L was the big square metal one. Im not sure if I have an early or late 73. The numbers that are supposed to be in the front trunk, and in the rear trunk are missing. Both trunks have been sprayed with "bed liner" I cannot find/see the engine number either. I have looked at the area where it is supposed to be, but cannot see anything. The earlier 1.7s (70-72) use a metal oil bath filter. 1973 1.7s they changed to a round plastic filter. 1.8s use a square plastic filter housing. The issue with the 73 round plastic housing is finding the proper filter elements for it. You can use the earlier metal filter as they are interchangeable however it would not be "correct" for the year. |
jkb081 Want to buy Original 1.7 air cleaner Jan 9 2022, 07:23 PM
Jamie
[quote name='jkb081' post='2973334' date='Jan 9 2... Jan 10 2022, 11:30 AM
jkb081
[quote name='jkb081' post='2973334' date='Jan 9 2... Jan 10 2022, 01:51 PM
jrmdir jkb081: Do you have the build date from the EPA st... Jan 10 2022, 12:16 PM
jkb081
jkb081: Do you have the build date from the EPA s... Jan 10 2022, 01:47 PM
JamesM
jkb081: Do you have the build date from the EPA s... Jan 11 2022, 10:58 AM
JamesM For reference this is what the original elements l... Jan 11 2022, 11:02 AM
euro911
For reference this is what the original elements ... Jan 12 2022, 11:35 AM
Jamie
[quote name='JamesM' post='2973663' date='Jan 11 ... Jan 12 2022, 11:50 AM
Sprout My '73 1.7 was built in Dec '72, and has t... Jan 10 2022, 01:28 PM
jrmdir QUOTE[I see. Thank you. My issue is the intake hor... Jan 10 2022, 02:19 PM
jkb081
[i]QUOTE[I see. Thank you. My issue is the intake... Jan 10 2022, 08:38 PM
Mikey914 ]This is why 914World is AWESOME!
[quote name=... Jan 11 2022, 12:56 PM
jkb081
[i]QUOTE[I see. Thank you. My issue is the intake... Jan 11 2022, 01:43 PM
Highland
Looking for complete air cleaner with mounting bo... Jan 10 2022, 04:59 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:47 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:54 PM
bdstone914
Looking for complete air cleaner with mounting bo... Jan 10 2022, 07:21 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:48 PM
Highland PM sent. Jan 11 2022, 10:48 AM
jrmdir Happy to help. I knew almost nothing about these c... Jan 11 2022, 02:23 PM
jkb081
Happy to help. I knew almost nothing about these ... Jan 11 2022, 02:42 PM
jrmdir The $7 WIX filter I ordered will be here this... Jan 12 2022, 01:12 PM
jrmdir PSA
Well, unfortunately, the NAPA 2909 discussed ... Jan 14 2022, 09:55 AM
JamesM
PSA
Well, unfortunately, the NAPA 2909 discussed... Jan 14 2022, 11:03 AM
Jamie
PSA
Well, unfortunately, the NAPA 2909 discussed... Jan 14 2022, 02:03 PM
Jamie
PSA
Well, unfortunately, the NAPA 2909 discusse... Jan 14 2022, 02:21 PM
rhodyguy That's a plastic housing? I wonder if the fitt... Jan 14 2022, 10:51 AM
JamesM Ok, so my K&N E3270 showed up and I made it ou... Feb 6 2022, 04:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 05:27 PM |
