> Want to buy Original 1.7 air cleaner, Looking for correct complete air cleaner for 1.7 motor
jkb081
post Jan 9 2022, 07:23 PM
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
jrmdir
post Jan 10 2022, 02:19 PM
QUOTE[I see. Thank you. My issue is the intake horn is pressing down on the flapper rod that connects both flappers, thus preventing it from proper function. So I assumed I have the incorrect air cleaner.]QUOTE
The horn should point to the side of the car. See below. You should be able to rotate the bottom of the cleaner (with the horn) when the clips are undone. The top half's orientation is fixed by the rubber connector to the throttle body.
As to the covered up numbers in the trunks, they would (should) be the same as the top number on the Karmann plate: 2639599. This means your car was built on the 3rd day of the 26th week (of 1973.) Or Wednesday, June 27th. This, and the high VIN# (27001) would put it fairly late in the '73 model run, which I believe would have ended in August or September.
The scratched out bottom number is the original paint code.
Ron
jkb081
post Jan 10 2022, 08:38 PM
QUOTE(jrmdir @ Jan 10 2022, 03:19 PM) *
Ron
Wow! Thanks a lot! That is the kind of information I have been looking for. I purchased George Hussy's book, but it is useless. I had some VW books that have all this kind of infomation, however because of a recent move, I cannot find them. The horn was pointing forward to the fire wall. I had rotated to the right to line up with the indents on the mounting bracket. I could not seat it because the horn ended up right on top of the distributer. I will take it apart again tomorrow. Thanks for the great information.
jkb081   Want to buy Original 1.7 air cleaner   Jan 9 2022, 07:23 PM
Mikey914   It should be plastic lnot the metal one.   Jan 9 2022, 07:35 PM
jkb081   It should be plastic lnot the metal one. OK, tha...   Jan 9 2022, 08:56 PM
JamesM   It should be plastic lnot the metal one. OK, th...   Jan 10 2022, 08:22 AM
Jamie   [quote name='jkb081' post='2973334' date='Jan 9 2...   Jan 10 2022, 11:30 AM
jkb081   [quote name='jkb081' post='2973334' date='Jan 9 2...   Jan 10 2022, 01:51 PM
jrmdir   jkb081: Do you have the build date from the EPA st...   Jan 10 2022, 12:16 PM
jkb081   jkb081: Do you have the build date from the EPA s...   Jan 10 2022, 01:47 PM
JamesM   jkb081: Do you have the build date from the EPA s...   Jan 11 2022, 10:58 AM
JamesM   For reference this is what the original elements l...   Jan 11 2022, 11:02 AM
euro911   For reference this is what the original elements ...   Jan 12 2022, 11:35 AM
Jamie   [quote name='JamesM' post='2973663' date='Jan 11 ...   Jan 12 2022, 11:50 AM
Sprout   My '73 1.7 was built in Dec '72, and has t...   Jan 10 2022, 01:28 PM
jrmdir   QUOTE[I see. Thank you. My issue is the intake hor...   Jan 10 2022, 02:19 PM
jkb081   [i]QUOTE[I see. Thank you. My issue is the intake...   Jan 10 2022, 08:38 PM
Mikey914   ]This is why 914World is AWESOME! [quote name=...   Jan 11 2022, 12:56 PM
jkb081   [i]QUOTE[I see. Thank you. My issue is the intake...   Jan 11 2022, 01:43 PM
Highland   Looking for complete air cleaner with mounting bo...   Jan 10 2022, 04:59 PM
jkb081   [quote name='jkb081' post='2973306' date='Jan 9 2...   Jan 10 2022, 08:47 PM
jkb081   [quote name='jkb081' post='2973306' date='Jan 9 2...   Jan 10 2022, 08:54 PM
bdstone914   Looking for complete air cleaner with mounting bo...   Jan 10 2022, 07:21 PM
jkb081   [quote name='jkb081' post='2973306' date='Jan 9 2...   Jan 10 2022, 08:48 PM
Highland   PM sent.   Jan 11 2022, 10:48 AM
jrmdir   Happy to help. I knew almost nothing about these c...   Jan 11 2022, 02:23 PM
jkb081   Happy to help. I knew almost nothing about these ...   Jan 11 2022, 02:42 PM
jrmdir   The $7 WIX filter I ordered will be here this...   Jan 12 2022, 01:12 PM
jrmdir   PSA Well, unfortunately, the NAPA 2909 discussed ...   Jan 14 2022, 09:55 AM
JamesM   PSA Well, unfortunately, the NAPA 2909 discussed...   Jan 14 2022, 11:03 AM
Jamie   PSA Well, unfortunately, the NAPA 2909 discussed...   Jan 14 2022, 02:03 PM
Jamie   PSA Well, unfortunately, the NAPA 2909 discusse...   Jan 14 2022, 02:21 PM
rhodyguy   That's a plastic housing? I wonder if the fitt...   Jan 14 2022, 10:51 AM
JamesM   Ok, so my K&N E3270 showed up and I made it ou...   Feb 6 2022, 04:41 PM
- Lo-Fi Version Time is now: 4th October 2026 - 05:27 PM
