| jkb081 |
Jan 9 2022, 07:23 PM
Member ![]() ![]() Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
| jrmdir |
Jan 10 2022, 02:19 PM
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest
QUOTE[I see. Thank you. My issue is the intake horn is pressing down on the flapper rod that connects both flappers, thus preventing it from proper function. So I assumed I have the incorrect air cleaner.]QUOTE
The horn should point to the side of the car. See below. You should be able to rotate the bottom of the cleaner (with the horn) when the clips are undone. The top half's orientation is fixed by the rubber connector to the throttle body. As to the covered up numbers in the trunks, they would (should) be the same as the top number on the Karmann plate: 2639599. This means your car was built on the 3rd day of the 26th week (of 1973.) Or Wednesday, June 27th. This, and the high VIN# (27001) would put it fairly late in the '73 model run, which I believe would have ended in August or September. The scratched out bottom number is the original paint code. Ron |
| jkb081 |
Jan 10 2022, 08:38 PM
QUOTE[I see. Thank you. My issue is the intake horn is pressing down on the flapper rod that connects both flappers, thus preventing it from proper function. So I assumed I have the incorrect air cleaner.]QUOTE The horn should point to the side of the car. See below. You should be able to rotate the bottom of the cleaner (with the horn) when the clips are undone. The top half's orientation is fixed by the rubber connector to the throttle body. As to the covered up numbers in the trunks, they would (should) be the same as the top number on the Karmann plate: 2639599. This means your car was built on the 3rd day of the 26th week (of 1973.) Or Wednesday, June 27th. This, and the high VIN# (27001) would put it fairly late in the '73 model run, which I believe would have ended in August or September. The scratched out bottom number is the original paint code. Ron Wow! Thanks a lot! That is the kind of information I have been looking for. I purchased George Hussy's book, but it is useless. I had some VW books that have all this kind of infomation, however because of a recent move, I cannot find them. The horn was pointing forward to the fire wall. I had rotated to the right to line up with the indents on the mounting bracket. I could not seat it because the horn ended up right on top of the distributer. I will take it apart again tomorrow. Thanks for the great information. |
| Mikey914 |
Jan 11 2022, 12:56 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
]This is why 914World is AWESOME!
[quote name='jkb081' post='2973566' date='Jan 10 2022, 06:38 Wow! Thanks a lot! That is the kind of information I have been looking for. I purchased George Hussy's book, but it is useless. I had some VW books that have all this kind of infomation, however because of a recent move, I cannot find them. The horn was pointing forward to the fire wall. I had rotated to the right to line up with the indents on the mounting bracket. I could not seat it because the horn ended up right on top of the distributer. I will take it apart again tomorrow. Thanks for the great information. [/quote] |
jkb081 Want to buy Original 1.7 air cleaner Jan 9 2022, 07:23 PM
Mikey914 It should be plastic lnot the metal one. Jan 9 2022, 07:35 PM
jkb081
OK, tha... Jan 9 2022, 08:56 PM
JamesM
OK, th... Jan 10 2022, 08:22 AM
Jamie
[quote name='jkb081' post='2973334' date='Jan 9 2... Jan 10 2022, 11:30 AM
jkb081
[quote name='jkb081' post='2973334' date='Jan 9 2... Jan 10 2022, 01:51 PM
jrmdir jkb081: Do you have the build date from the EPA st... Jan 10 2022, 12:16 PM
jkb081
jkb081: Do you have the build date from the EPA s... Jan 10 2022, 01:47 PM
JamesM
jkb081: Do you have the build date from the EPA s... Jan 11 2022, 10:58 AM
JamesM For reference this is what the original elements l... Jan 11 2022, 11:02 AM
euro911
For reference this is what the original elements ... Jan 12 2022, 11:35 AM
Jamie
[quote name='JamesM' post='2973663' date='Jan 11 ... Jan 12 2022, 11:50 AM
Sprout My '73 1.7 was built in Dec '72, and has t... Jan 10 2022, 01:28 PM
jkb081
[i]QUOTE[I see. Thank you. My issue is the intake... Jan 11 2022, 01:43 PM
Highland
Looking for complete air cleaner with mounting bo... Jan 10 2022, 04:59 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:47 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:54 PM
bdstone914
Looking for complete air cleaner with mounting bo... Jan 10 2022, 07:21 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:48 PM
Highland PM sent. Jan 11 2022, 10:48 AM
jrmdir Happy to help. I knew almost nothing about these c... Jan 11 2022, 02:23 PM
jkb081
Happy to help. I knew almost nothing about these ... Jan 11 2022, 02:42 PM
jrmdir The $7 WIX filter I ordered will be here this... Jan 12 2022, 01:12 PM
jrmdir PSA
Well, unfortunately, the NAPA 2909 discussed ... Jan 14 2022, 09:55 AM
JamesM
PSA
Well, unfortunately, the NAPA 2909 discussed... Jan 14 2022, 11:03 AM
Jamie
PSA
Well, unfortunately, the NAPA 2909 discussed... Jan 14 2022, 02:03 PM
Jamie
PSA
Well, unfortunately, the NAPA 2909 discusse... Jan 14 2022, 02:21 PM
rhodyguy That's a plastic housing? I wonder if the fitt... Jan 14 2022, 10:51 AM
JamesM Ok, so my K&N E3270 showed up and I made it ou... Feb 6 2022, 04:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th October 2026 - 06:49 PM |
