| jkb081 |
Jan 9 2022, 07:23 PM
Member ![]() ![]() Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
| jrmdir |
Jan 11 2022, 02:23 PM
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest
Happy to help. I knew almost nothing about these cars 6 months ago and learned everything from the helpful folks here!
There are a lot of threads on engine numbers, and a lot of people more into them than I am, but based on the numbers on my original '73, yours look to be correct. Or at least not out of whack. Hopefully others will chime in. One thing you should do, if not already, is to put your info into the VIN Database (top thread in this forum) Once your car is slotted in, you may be able to see some engine #'s of cars that were built at or nearly at the same time. Could be a good gut check. Cheers, Ron |
jkb081 Want to buy Original 1.7 air cleaner Jan 9 2022, 07:23 PM
Mikey914 It should be plastic lnot the metal one. Jan 9 2022, 07:35 PM
jkb081
OK, tha... Jan 9 2022, 08:56 PM
JamesM
OK, th... Jan 10 2022, 08:22 AM
Jamie
[quote name='jkb081' post='2973334' date='Jan 9 2... Jan 10 2022, 11:30 AM
jkb081
[quote name='jkb081' post='2973334' date='Jan 9 2... Jan 10 2022, 01:51 PM
jrmdir jkb081: Do you have the build date from the EPA st... Jan 10 2022, 12:16 PM
jkb081
jkb081: Do you have the build date from the EPA s... Jan 10 2022, 01:47 PM
JamesM
jkb081: Do you have the build date from the EPA s... Jan 11 2022, 10:58 AM
JamesM For reference this is what the original elements l... Jan 11 2022, 11:02 AM
euro911
For reference this is what the original elements ... Jan 12 2022, 11:35 AM
Jamie
[quote name='JamesM' post='2973663' date='Jan 11 ... Jan 12 2022, 11:50 AM
Sprout My '73 1.7 was built in Dec '72, and has t... Jan 10 2022, 01:28 PM
jrmdir QUOTE[I see. Thank you. My issue is the intake hor... Jan 10 2022, 02:19 PM
jkb081
[i]QUOTE[I see. Thank you. My issue is the intake... Jan 10 2022, 08:38 PM
Mikey914 ]This is why 914World is AWESOME!
[quote name=... Jan 11 2022, 12:56 PM
jkb081
[i]QUOTE[I see. Thank you. My issue is the intake... Jan 11 2022, 01:43 PM
Highland
Looking for complete air cleaner with mounting bo... Jan 10 2022, 04:59 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:47 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:54 PM
bdstone914
Looking for complete air cleaner with mounting bo... Jan 10 2022, 07:21 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:48 PM
Highland PM sent. Jan 11 2022, 10:48 AM
jkb081
Happy to help. I knew almost nothing about these ... Jan 11 2022, 02:42 PM
jrmdir The $7 WIX filter I ordered will be here this... Jan 12 2022, 01:12 PM
jrmdir PSA
Well, unfortunately, the NAPA 2909 discussed ... Jan 14 2022, 09:55 AM
JamesM
PSA
Well, unfortunately, the NAPA 2909 discussed... Jan 14 2022, 11:03 AM
Jamie
PSA
Well, unfortunately, the NAPA 2909 discussed... Jan 14 2022, 02:03 PM
Jamie
PSA
Well, unfortunately, the NAPA 2909 discusse... Jan 14 2022, 02:21 PM
rhodyguy That's a plastic housing? I wonder if the fitt... Jan 14 2022, 10:51 AM
JamesM Ok, so my K&N E3270 showed up and I made it ou... Feb 6 2022, 04:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 05:27 PM |
