> Want to buy Original 1.7 air cleaner, Looking for correct complete air cleaner for 1.7 motor
jkb081
post Jan 9 2022, 07:23 PM
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
jrmdir
post Jan 11 2022, 02:23 PM
Happy to help. I knew almost nothing about these cars 6 months ago and learned everything from the helpful folks here!
There are a lot of threads on engine numbers, and a lot of people more into them than I am, but based on the numbers on my original '73, yours look to be correct. Or at least not out of whack. Hopefully others will chime in.
One thing you should do, if not already, is to put your info into the VIN Database (top thread in this forum) Once your car is slotted in, you may be able to see some engine #'s of cars that were built at or nearly at the same time. Could be a good gut check.
Cheers,
Ron
jkb081
post Jan 11 2022, 02:42 PM
QUOTE(jrmdir @ Jan 11 2022, 03:23 PM) *
Cheers,
Ron
Thanks!
jkb081   Want to buy Original 1.7 air cleaner   Jan 9 2022, 07:23 PM
Mikey914   It should be plastic lnot the metal one.   Jan 9 2022, 07:35 PM
jkb081   It should be plastic lnot the metal one. OK, tha...   Jan 9 2022, 08:56 PM
JamesM   It should be plastic lnot the metal one. OK, th...   Jan 10 2022, 08:22 AM
Jamie   [quote name='jkb081' post='2973334' date='Jan 9 2...   Jan 10 2022, 11:30 AM
jkb081   [quote name='jkb081' post='2973334' date='Jan 9 2...   Jan 10 2022, 01:51 PM
jrmdir   jkb081: Do you have the build date from the EPA st...   Jan 10 2022, 12:16 PM
jkb081   jkb081: Do you have the build date from the EPA s...   Jan 10 2022, 01:47 PM
JamesM   jkb081: Do you have the build date from the EPA s...   Jan 11 2022, 10:58 AM
JamesM   For reference this is what the original elements l...   Jan 11 2022, 11:02 AM
euro911   For reference this is what the original elements ...   Jan 12 2022, 11:35 AM
Jamie   [quote name='JamesM' post='2973663' date='Jan 11 ...   Jan 12 2022, 11:50 AM
Sprout   My '73 1.7 was built in Dec '72, and has t...   Jan 10 2022, 01:28 PM
jrmdir   QUOTE[I see. Thank you. My issue is the intake hor...   Jan 10 2022, 02:19 PM
jkb081   [i]QUOTE[I see. Thank you. My issue is the intake...   Jan 10 2022, 08:38 PM
Mikey914   ]This is why 914World is AWESOME! [quote name=...   Jan 11 2022, 12:56 PM
jkb081   [i]QUOTE[I see. Thank you. My issue is the intake...   Jan 11 2022, 01:43 PM
Highland   Looking for complete air cleaner with mounting bo...   Jan 10 2022, 04:59 PM
jkb081   [quote name='jkb081' post='2973306' date='Jan 9 2...   Jan 10 2022, 08:47 PM
jkb081   [quote name='jkb081' post='2973306' date='Jan 9 2...   Jan 10 2022, 08:54 PM
bdstone914   Looking for complete air cleaner with mounting bo...   Jan 10 2022, 07:21 PM
jkb081   [quote name='jkb081' post='2973306' date='Jan 9 2...   Jan 10 2022, 08:48 PM
Highland   PM sent.   Jan 11 2022, 10:48 AM
jrmdir   Happy to help. I knew almost nothing about these c...   Jan 11 2022, 02:23 PM
jkb081   Happy to help. I knew almost nothing about these ...   Jan 11 2022, 02:42 PM
jrmdir   The $7 WIX filter I ordered will be here this...   Jan 12 2022, 01:12 PM
jrmdir   PSA Well, unfortunately, the NAPA 2909 discussed ...   Jan 14 2022, 09:55 AM
JamesM   PSA Well, unfortunately, the NAPA 2909 discussed...   Jan 14 2022, 11:03 AM
Jamie   PSA Well, unfortunately, the NAPA 2909 discussed...   Jan 14 2022, 02:03 PM
Jamie   PSA Well, unfortunately, the NAPA 2909 discusse...   Jan 14 2022, 02:21 PM
rhodyguy   That's a plastic housing? I wonder if the fitt...   Jan 14 2022, 10:51 AM
JamesM   Ok, so my K&N E3270 showed up and I made it ou...   Feb 6 2022, 04:41 PM
- Lo-Fi Version Time is now: 4th October 2026 - 05:26 PM
