> Want to buy Original 1.7 air cleaner, Looking for correct complete air cleaner for 1.7 motor
jkb081
post Jan 9 2022, 07:23 PM
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
jrmdir
post Jan 10 2022, 12:16 PM
jkb081: Do you have the build date from the EPA sticker on the rear door jamb? If not, how about the production number above the paint code on the Karmann plate in the front door jamb?
My '73 1.7 was built in September of '72 and has the round plastic cleaner, if that helps.
Also, Jamie: Thanks for the NAPA part number info! Just what I've been looking for.
BTW, NAPA website shows no options for ordering or picking one up, so it may be NLA. However, they cross reference to WIX 42909 and I found them on eBay for less than $7.
Thanks again.
Ron
JamesM
post Jan 11 2022, 10:58 AM
QUOTE(jrmdir @ Jan 10 2022, 11:16 AM) *
Thanks again.
Ron
There was a thread on 1.7 filter elements a while back that has the details, but at that time while there were available replacements that would "fit" in the air filter housing none of the options i checked out actually sealed properly and hence wouldn't be actual filtering any air. The original filter has a raised ring in the center to create the air seal while all aftermarket options even if they are the same factory dimensions lack this detail and allow air over the top of the filter. Others had to large an ID and you could hear them flopping around in the housing if you shook it.
I have a collection of proper elements out in my garage, ill see if i can get a picture later to show you what i am talking about. Or you might be able to find the old thread with the details.
JamesM
post Jan 11 2022, 11:02 AM
For reference this is what the original elements looked like
Found one on ebay, didnt need to go to the garage (IMG:style_emoticons/default/smile.gif)
https://www.ebay.com/itm/284384653249
euro911
post Jan 12 2022, 11:35 AM
QUOTE(JamesM @ Jan 11 2022, 09:02 AM) *
Maybe 'Mr. Rubber' can produce a rubber ring to place on top of the NAPA and WIX elements to help achieve proper sealing ??? (IMG:style_emoticons/default/idea.gif) ???
(IMG:style_emoticons/default/poke.gif) ( @mikey914 )
Jamie
post Jan 12 2022, 11:50 AM
QUOTE(euro911 @ Jan 12 2022, 09:35 AM) *
Maybe 'Mr. Rubber' ( @mikey914 ) can produce a rubber ring to place on top of the NAPA and WIX elements to help achieve proper sealing ??? (IMG:style_emoticons/default/idea.gif) ???
What? No rubber ring needed for seal if proper filter is selected. :shades2:eBay post is way overpriced! (IMG:style_emoticons/default/hissyfit.gif)
jkb081   Want to buy Original 1.7 air cleaner   Jan 9 2022, 07:23 PM
Mikey914   It should be plastic lnot the metal one.   Jan 9 2022, 07:35 PM
jkb081   It should be plastic lnot the metal one. OK, tha...   Jan 9 2022, 08:56 PM
JamesM   It should be plastic lnot the metal one. OK, th...   Jan 10 2022, 08:22 AM
Jamie   [quote name='jkb081' post='2973334' date='Jan 9 2...   Jan 10 2022, 11:30 AM
jkb081   [quote name='jkb081' post='2973334' date='Jan 9 2...   Jan 10 2022, 01:51 PM
jrmdir   jkb081: Do you have the build date from the EPA st...   Jan 10 2022, 12:16 PM
jkb081   jkb081: Do you have the build date from the EPA s...   Jan 10 2022, 01:47 PM
JamesM   jkb081: Do you have the build date from the EPA s...   Jan 11 2022, 10:58 AM
JamesM   For reference this is what the original elements l...   Jan 11 2022, 11:02 AM
euro911   For reference this is what the original elements ...   Jan 12 2022, 11:35 AM
Jamie   [quote name='JamesM' post='2973663' date='Jan 11 ...   Jan 12 2022, 11:50 AM
Sprout   My '73 1.7 was built in Dec '72, and has t...   Jan 10 2022, 01:28 PM
jrmdir   QUOTE[I see. Thank you. My issue is the intake hor...   Jan 10 2022, 02:19 PM
jkb081   [i]QUOTE[I see. Thank you. My issue is the intake...   Jan 10 2022, 08:38 PM
Mikey914   ]This is why 914World is AWESOME! [quote name=...   Jan 11 2022, 12:56 PM
jkb081   [i]QUOTE[I see. Thank you. My issue is the intake...   Jan 11 2022, 01:43 PM
Highland   Looking for complete air cleaner with mounting bo...   Jan 10 2022, 04:59 PM
jkb081   [quote name='jkb081' post='2973306' date='Jan 9 2...   Jan 10 2022, 08:47 PM
jkb081   [quote name='jkb081' post='2973306' date='Jan 9 2...   Jan 10 2022, 08:54 PM
bdstone914   Looking for complete air cleaner with mounting bo...   Jan 10 2022, 07:21 PM
jkb081   [quote name='jkb081' post='2973306' date='Jan 9 2...   Jan 10 2022, 08:48 PM
Highland   PM sent.   Jan 11 2022, 10:48 AM
jrmdir   Happy to help. I knew almost nothing about these c...   Jan 11 2022, 02:23 PM
jkb081   Happy to help. I knew almost nothing about these ...   Jan 11 2022, 02:42 PM
jrmdir   The $7 WIX filter I ordered will be here this...   Jan 12 2022, 01:12 PM
jrmdir   PSA Well, unfortunately, the NAPA 2909 discussed ...   Jan 14 2022, 09:55 AM
JamesM   PSA Well, unfortunately, the NAPA 2909 discussed...   Jan 14 2022, 11:03 AM
Jamie   PSA Well, unfortunately, the NAPA 2909 discussed...   Jan 14 2022, 02:03 PM
Jamie   PSA Well, unfortunately, the NAPA 2909 discusse...   Jan 14 2022, 02:21 PM
rhodyguy   That's a plastic housing? I wonder if the fitt...   Jan 14 2022, 10:51 AM
JamesM   Ok, so my K&N E3270 showed up and I made it ou...   Feb 6 2022, 04:41 PM
- Lo-Fi Version Time is now: 4th October 2026 - 05:26 PM
