| jkb081 |
Jan 9 2022, 07:23 PM
Member ![]() ![]() Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
| jrmdir |
Jan 14 2022, 09:55 AM
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest
PSA
Well, unfortunately, the NAPA 2909 discussed above does NOT fit the stock 1.7 round cleaner. It's way off (yellow circle is what the ID needs to be.) The return shipping exceeds the original cost so if anyone needs it let me know. Ron ![]() |
| Jamie |
Jan 14 2022, 02:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,229 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
PSA Well, unfortunately, the NAPA 2909 discussed above does NOT fit the stock 1.7 round cleaner. It's way off (yellow circle is what the ID needs to be.) The return shipping exceeds the original cost so if anyone needs it let me know. Ron ![]() I've run the NAPA 2909 filter in my all original 73 1.7L for years, not fitment problem. The filter in your photo appears to be much larger than the inside diameter of my filter which is 6.5"? (IMG:style_emoticons/default/confused24.gif) |
| Jamie |
Jan 14 2022, 02:21 PM
PSA Well, unfortunately, the NAPA 2909 discussed above does NOT fit the stock 1.7 round cleaner. It's way off (yellow circle is what the ID needs to be.) The return shipping exceeds the original cost so if anyone needs it let me know. Ron ![]() I've run the NAPA 2909 filter in my all original 73 1.7L for years, not fitment problem. The filter in your photo appears to be much larger than the inside diameter of my filter which is 6.5"? (IMG:style_emoticons/default/confused24.gif) Hold the horses, I just measured my air filter, and the NAPA box is labeled #2909 but the filter has #2011 inside! That is the filter I've been running in the 73 air filter housing all these years. (IMG:style_emoticons/default/confused24.gif) .Sorry for the confusion y'all! |
jkb081 Want to buy Original 1.7 air cleaner Jan 9 2022, 07:23 PM
Mikey914 It should be plastic lnot the metal one. Jan 9 2022, 07:35 PM
jkb081
OK, tha... Jan 9 2022, 08:56 PM
JamesM
OK, th... Jan 10 2022, 08:22 AM
Jamie
[quote name='jkb081' post='2973334' date='Jan 9 2... Jan 10 2022, 11:30 AM
jkb081
[quote name='jkb081' post='2973334' date='Jan 9 2... Jan 10 2022, 01:51 PM
jrmdir jkb081: Do you have the build date from the EPA st... Jan 10 2022, 12:16 PM
jkb081
jkb081: Do you have the build date from the EPA s... Jan 10 2022, 01:47 PM
JamesM
jkb081: Do you have the build date from the EPA s... Jan 11 2022, 10:58 AM
JamesM For reference this is what the original elements l... Jan 11 2022, 11:02 AM
euro911
For reference this is what the original elements ... Jan 12 2022, 11:35 AM
Jamie
[quote name='JamesM' post='2973663' date='Jan 11 ... Jan 12 2022, 11:50 AM
Sprout My '73 1.7 was built in Dec '72, and has t... Jan 10 2022, 01:28 PM
jrmdir QUOTE[I see. Thank you. My issue is the intake hor... Jan 10 2022, 02:19 PM
jkb081
[i]QUOTE[I see. Thank you. My issue is the intake... Jan 10 2022, 08:38 PM
Mikey914 ]This is why 914World is AWESOME!
[quote name=... Jan 11 2022, 12:56 PM
jkb081
[i]QUOTE[I see. Thank you. My issue is the intake... Jan 11 2022, 01:43 PM
Highland
Looking for complete air cleaner with mounting bo... Jan 10 2022, 04:59 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:47 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:54 PM
bdstone914
Looking for complete air cleaner with mounting bo... Jan 10 2022, 07:21 PM
jkb081
[quote name='jkb081' post='2973306' date='Jan 9 2... Jan 10 2022, 08:48 PM
Highland PM sent. Jan 11 2022, 10:48 AM
jrmdir Happy to help. I knew almost nothing about these c... Jan 11 2022, 02:23 PM
jkb081
Happy to help. I knew almost nothing about these ... Jan 11 2022, 02:42 PM
jrmdir The $7 WIX filter I ordered will be here this... Jan 12 2022, 01:12 PM
JamesM
PSA
Well, unfortunately, the NAPA 2909 discussed... Jan 14 2022, 11:03 AM
rhodyguy That's a plastic housing? I wonder if the fitt... Jan 14 2022, 10:51 AM
JamesM Ok, so my K&N E3270 showed up and I made it ou... Feb 6 2022, 04:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 05:26 PM |
