| Cal |
Jan 10 2022, 04:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
I'm considering updating my sealed beam headlights with period correct H4's. What's the maximum wattage bulb that can be installed without having to install relays? In the past I've installed H1's with 100/80 watt bulbs in my early SWB 911 and I needed to install relays. I'm not interested in LED lights.
Attached thumbnail(s) |
| Cairo94507 |
Jan 11 2022, 11:22 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,511 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I had the GE Nighthawk lights in my car and they performed exceptionally well. The only reason I swapped to the H4 LED kit is I wanted the car to look as stock as possible. The performance of the GE lights was amazing. My LED's are good, but not as good as the Nighthawks were. For the few times I drive the car at night, I am fine with the H4 LED's. (IMG:style_emoticons/default/beerchug.gif)
| ctc911ctc |
Jan 15 2022, 10:46 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,287 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
I too HAVE the GE Nighthawks. However, I first installed period correct EVERYTHING and then we to the H4's with Halogens.....extra power with a relay kit. Still not good enough........Soooooooo, I found a pair of Nighthawks ($$$$$) that were still in the box new and installed. Wow,
I am this weekend installing LED's in the dash. When I was in my 20's I did not notice how dim the dash was, perhaps because I did not care.......but now I need more Lumens........much more...... I had the GE Nighthawk lights in my car and they performed exceptionally well. The only reason I swapped to the H4 LED kit is I wanted the car to look as stock as possible. The performance of the GE lights was amazing. My LED's are good, but not as good as the Nighthawks were. For the few times I drive the car at night, I am fine with the H4 LED's. (IMG:style_emoticons/default/beerchug.gif) |
| mepstein |
Jan 15 2022, 11:59 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,281 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I too HAVE the GE Nighthawks. However, I first installed period correct EVERYTHING and then we to the H4's with Halogens.....extra power with a relay kit. Still not good enough........Soooooooo, I found a pair of Nighthawks ($$$$$) that were still in the box new and installed. Wow, I am this weekend installing LED's in the dash. When I was in my 20's I did not notice how dim the dash was, perhaps because I did not care.......but now I need more Lumens........much more...... I had the GE Nighthawk lights in my car and they performed exceptionally well. The only reason I swapped to the H4 LED kit is I wanted the car to look as stock as possible. The performance of the GE lights was amazing. My LED's are good, but not as good as the Nighthawks were. For the few times I drive the car at night, I am fine with the H4 LED's. (IMG:style_emoticons/default/beerchug.gif) I’m a bit different. I love the nighthawk led lights but keep the gauge lights dim. I prefer it like that in all my cars. Bright dash lights bother me. |
| fixer34 |
Jan 15 2022, 01:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,359 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
I too HAVE the GE Nighthawks. However, I first installed period correct EVERYTHING and then we to the H4's with Halogens.....extra power with a relay kit. Still not good enough........Soooooooo, I found a pair of Nighthawks ($$$$$) that were still in the box new and installed. Wow, I am this weekend installing LED's in the dash. When I was in my 20's I did not notice how dim the dash was, perhaps because I did not care.......but now I need more Lumens........much more...... I had the GE Nighthawk lights in my car and they performed exceptionally well. The only reason I swapped to the H4 LED kit is I wanted the car to look as stock as possible. The performance of the GE lights was amazing. My LED's are good, but not as good as the Nighthawks were. For the few times I drive the car at night, I am fine with the H4 LED's. (IMG:style_emoticons/default/beerchug.gif) I’m a bit different. I love the nighthawk led lights but keep the gauge lights dim. I prefer it like that in all my cars. Bright dash lights bother me. Maybe the answer is in here somewhere and I didn't catch it. I replaced my sealed beams with Cibie Z-beam housings and H4 halogen 40+ years ago (probably illegal at the time...). One bulb finally went out about 2 years ago and I replaced both with 9003/HB2/H4 60/55w bulbs. I don't drive much at night, but really like the Z-beam cutoff on low. Is there a straight LED bulb replacement? white 5000k preferred. This is a factory -6 if that makes a difference. No fog lights (yet..) |
Cal H4 Headlights Jan 10 2022, 04:14 PM
914Sixer You will have to stick with what you have there 60... Jan 10 2022, 04:47 PM
brant even with the smaller bulbs...
your still putting ... Jan 10 2022, 04:54 PM
Cairo94507 Please consider doing the LED conversion on those ... Jan 11 2022, 09:30 AM
JmuRiz I have 60/55 H4 upgrades on mine...never had an is... Jan 11 2022, 09:53 AM
Warren914 How will it look different with LED bulbs? Are you... Jan 11 2022, 10:15 AM
JmuRiz LED bulbs don't really work well, I'm goin... Jan 11 2022, 10:48 AM
horizontally-opposed
LED bulbs don't really work well, I'm goi... Jan 11 2022, 07:37 PM
Mark Henry I broke down and bought a set of the 914rubber LED... Jan 11 2022, 11:09 AM
I had the GE Nighthawk lights in my car and they ... Jan 11 2022, 07:54 PM
Driver174 Although my objective may be different; don't ... Jan 11 2022, 11:52 AM
brant I ran 80/100 for from 86? to 2017?
The altern... Jan 11 2022, 07:48 PM
iankarr I put LED's in both of my 914s and the differe... Jan 11 2022, 08:42 PM
Bruce Hinds
I put LED's in both of my 914s and the differ... Nov 28 2022, 12:05 AM
JmuRiz Holley is making a stock look one now too, might b... Jan 11 2022, 10:28 PM
horizontally-opposed Nice find! The Holley lights look good. Only q... Jan 11 2022, 11:38 PM
horizontally-opposed (With apologies to Cal for derailing his thread. I... Jan 11 2022, 11:40 PM
rgalla9146 Note to self re 100w Halogens;
......install re... Jan 12 2022, 06:58 AM
Cairo94507 I agree. Nathan seems to have found a great solut... Jan 12 2022, 09:21 AM
Jamie I installed VintageCar LED headlamps 2 yrs. ago af... Jan 12 2022, 09:36 AM
rjames
I installed VintageCar LED headlamps 2 yrs. ago a... Jan 12 2022, 10:38 AM
brant
I installed VintageCar LED headlamps 2 yrs. ago ... Jan 12 2022, 11:21 AM
Jamie
I installed VintageCar LED headlamps 2 yrs. ago ... Jan 12 2022, 11:45 AM
Warren914 My car has Hella glass H4 lenses already. Is the o... Jan 13 2022, 06:41 AM
Jamie
My car has Hella glass H4 lenses already. Is the ... Jan 13 2022, 08:06 AM
FlacaProductions I have the 914rubber globes and LEDs in daylight/5... Jan 12 2022, 10:29 AM
eric9144 LED's are a huge improvement, I agree on the a... Jan 12 2022, 06:52 PM
BillJ VintageLEDs went on the silver car i sold and they... Jan 13 2022, 08:24 AM
ClayPerrine When I built my six conversion, I put in the 914-6... Jan 15 2022, 09:49 AM
danimal16 I installed the 914 Rubber H4 LED kit. What a dif... Oct 21 2022, 02:20 PM
Root_Werks Does anyone have issues with LED's freezing up... Oct 21 2022, 02:26 PM
bbrock
Does anyone have issues with LED's freezing u... Oct 21 2022, 06:41 PM
rjames
Does anyone have issues with LED's freezing ... Oct 21 2022, 08:44 PM
Superhawk996
Too many dipshits on the road blinding oncoming t... Oct 22 2022, 10:32 AM
bbrock
Too many dipshits on the road blinding oncoming ... Oct 22 2022, 01:27 PM
I've said it before and will say it again. I... Oct 22 2022, 04:29 PM
bbrock
My hangup is wanting modern LED performance and e... Oct 22 2022, 06:17 PM
Jamie
I've said it before and will say it again. ... Nov 28 2022, 09:25 AM
kerensky
I've said it before and will say it again. I... Nov 28 2022, 05:33 PM
Cairo94507 I see Vintage Car LED's have upgraded their 7... Oct 21 2022, 04:26 PM
sportlicherFahrer
Does anyone have issues with LED's freezing u... Oct 21 2022, 04:49 PM
Root_Werks
Does anyone have issues with LED's freezing ... Oct 22 2022, 10:15 AM
bbrock
In the case of our Jeep, it was frost not snow. F... Oct 22 2022, 06:33 PM
mb911 These are ones my sons 944 has and they are amazin... Oct 22 2022, 07:06 AM
Cairo94507 My only question for those is how far out does the... Oct 22 2022, 04:40 PM
burton73 let there be light!
LED done by PMB PERFORMAN... Nov 28 2022, 10:02 PM
porschetub
let there be light!
LED done by PMB PERFORMA... Nov 29 2022, 05:49 PM
Bob B
Nov 29 2022, 06:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 12:51 AM |
