Mars on a budget, 75 914 field-find into cool driver |
Mayne |
Mar 20 2017, 08:39 PM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
I thought I'd formally introduce my 914 project, now that I've been lurking on this great forum for a while.
A little back story: my younger brother and I are car fanatics, especially those of the German variety. He owns multiple BMWs, an early 911 with RS bodywork, and a manual 928, and I own an early Boxster, a 944 Turbo, and now the 914. Last summer, my brother went to check out an E36 parts car for his M3 in rural New Mexico. Sitting under some trees was this solid but rather forlorn looking 914: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063976.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063977.2.jpg) $1800 later, we towed home a mouse infested ran-when-parked 75 914. The 1.8 FI engine had been swapped out for a 1.7 with 1.8 heads and a single Weber carb, and the impact bumpers had been backdated to chrome bumpers. Mars Red with Mahle gas burners! (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063977.3.jpg) It had been parked because the previous owner thought it had developed a serious front main seal leak. We got it running with a minimum of effort and saw the significant oil leak. We impulsively dropped the motor and resealed the oil pump, suspecting that might solve the problem. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063978.4.jpg) Motor back in, along with a dual Weber setup we came across, it seemed like the leak was fixed. But it was running so badly, we couldn't really drive it. Since my brother was working part time at a Ferrari shop that primarily builds vintage motors, we were able to get the carbs rebuilt for cheap by the excellent Ferrari mechanic. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1490063978.5.jpg) Now with the car running much better, two thing were apparent, 914s are fun (IMG:style_emoticons/default/driving.gif) and we didn't fix the oil leak. (IMG:style_emoticons/default/WTF.gif) About this time, my growing love for this 914 was finally too much to resist. So my brother and I made a trade on his half of the purchase price for a ran-when-parked manual 928 that I had picked up. Still not sure who ended up with the better half of that deal, but we're both happy! With the car mine now, I started in on some of the needed projects. Thanks to 914World, I solved the major oil leak with a bolt in thermostat pulley hole (quite a bit easier than dropping the motor). With that dealt with, I could see a decent driver on the horizon. More soon! Cheers, Jeremy |
Mayne |
Jan 25 2022, 03:16 PM
In working on the front of the car so much, I decided to deal with some body damage that has bugged me for as long as I've owned the car. I wasn't really planning on doing it at this stage, because I really want to complete the Subaru 6 conversion to the point of running and driving before I tackle body and paint. But dealing with the front end damage (to some extent, at least) makes me feel better moving forward.
I also plan to do similar work in the engine bay before putting the new engine in, so when it is finally time to strip it down for paint, much of the "B surface" work will be pretty good. I know many people start with paint and body, then do the powertrain, but for me it makes the most sense to do any cutting, welding and modifying to the body first so I don't have to cut into a freshly painted body (though I'm sure some of that will have to happen anyway). I detailed some of this in a separate thread recently, so I'm just getting all the info into the build thread here. Body damage and surface rust. The structure was reasonably pulled, but there was no effort to treat the bare metal, so a lot of superficial rust: I cut the worst of the kink, then put a ratcheting strap on it to pull it inward a little. This really didn't move it too much, though maybe if I had cut it more, it would have. At any rate, added some metal to the opening and welded it up. I did some hammer and dolly work, then added some filler and seam sealer. Before priming, I added extra holes between the factory holes in the nose for better airflow to the radiator. I cut some mesh, which wasn't quite long enough to span the distance. A few spot welds made it into one piece and I tacked it into place. |
Lo-Fi Version | Time is now: 5th June 2024 - 06:56 AM |
