| emerygt350 |
Jan 30 2022, 12:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,796 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
| wonkipop |
Jan 31 2022, 02:32 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,758 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
dumb question from dumb australian.
but why the fuch do they still use salt. its the 21st century. isn't there something better out there? it hit 35.5C today. there was a lot of salt residue all over me. sweating it out on the falcon ute down at the workshop. i hope i am not making it rust again. i did not approach within 40 feet of the 914. |
| PatrickB |
Feb 1 2022, 04:22 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
dumb question from dumb australian. but why the fuch do they still use salt. its the 21st century. isn't there something better out there? it hit 35.5C today. there was a lot of salt residue all over me. sweating it out on the falcon ute down at the workshop. i hope i am not making it rust again. i did not approach within 40 feet of the 914. We still use salt because it's effective and cheaper than anything else. There are alternatives but they all cost a LOT more money. (I'm a roads supervisor ). We use brine to help the salt get started at it's job and to stop the salt from bouncing off the road when it comes out of the truck (pre-wet). Salt won't work unless it's wet, and won't work at all below about -12 or -14 c . Sand is okay up to a point and works at colder temperatures, but needs to be applied at a much higher rate which means more trucks on the road. Also needs to be stored inside so it doesn't freeze solid, means we need a huge building to put it in. And yes, we DO have to try to make the roads idiot proof to avoid lawsuits. Lots of times I drive to work just fine before the plow/salt trucks are out, but there's always people going in the ditch. |
| 930cabman |
Feb 1 2022, 05:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,871 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
dumb question from dumb australian. but why the fuch do they still use salt. its the 21st century. isn't there something better out there? it hit 35.5C today. there was a lot of salt residue all over me. sweating it out on the falcon ute down at the workshop. i hope i am not making it rust again. i did not approach within 40 feet of the 914. We still use salt because it's effective and cheaper than anything else. There are alternatives but they all cost a LOT more money. (I'm a roads supervisor ). We use brine to help the salt get started at it's job and to stop the salt from bouncing off the road when it comes out of the truck (pre-wet). Salt won't work unless it's wet, and won't work at all below about -12 or -14 c . Sand is okay up to a point and works at colder temperatures, but needs to be applied at a much higher rate which means more trucks on the road. Also needs to be stored inside so it doesn't freeze solid, means we need a huge building to put it in. And yes, we DO have to try to make the roads idiot proof to avoid lawsuits. Lots of times I drive to work just fine before the plow/salt trucks are out, but there's always people going in the ditch. Often times the idiots with 4WD, or just plain bad drivers. Always a good rule to keep it slow whenever snow/ice is on the roads |
emerygt350 Got salt? Jan 30 2022, 12:08 PM
Van B Checks… I won’t be driving either Porsche unti... Jan 30 2022, 12:20 PM
ClayPerrine EWWWWWWW Nasty white stuff covering the ground...... Jan 30 2022, 12:23 PM
Van B
[size=5][b]EWWWWWWW Nasty white stuff covering t... Jan 30 2022, 12:40 PM
wonkipop it looks purty when it first falls.
as i remember... Jan 30 2022, 03:24 PM
StarBear
as i remembe... Jan 30 2022, 03:30 PM
wonkipop
as i rememb... Jan 30 2022, 03:45 PM
emerygt350 For those of you that may not experience this... ... Jan 30 2022, 04:38 PM
930cabman
For those of you that may not experience this... ... Jan 30 2022, 05:33 PM
ClayPerrine
For those of you that may not experience this... ... Feb 1 2022, 07:08 AM
emerygt350 Luckily the Porsche is trapped behind feet of snow... Jan 30 2022, 07:02 PM
bkrantz Careful! Even talking about salt near a 914 c... Jan 30 2022, 10:02 PM
930cabman
but why the ... Jan 31 2022, 06:04 AM
bkrantz
but why the... Jan 31 2022, 09:36 PM
74ravenna
Why yes, that is dry pavement.
Yep, that's... Jan 31 2022, 05:24 AM
mlindner Wisconsin last week -23 deg in the morning.....But... Jan 31 2022, 06:39 AM
VaccaRabite http://www.914world.com/bbs2/uploads_offsite/live.... Jan 31 2022, 08:46 AM
dhuckabay Think you will find that this is magnesium chlorid... Jan 31 2022, 10:15 AM
Van B That checks. The brine is designed to not wash awa... Jan 31 2022, 09:00 AM
beech4rd
That checks. The brine is designed to not wash aw... Jan 31 2022, 09:10 AM
VaccaRabite
That checks. The brine is designed to not wash a... Jan 31 2022, 09:42 AM
Van B In my limited experience (since 2019), the rock sa... Jan 31 2022, 09:46 AM
Shivers
In my limited experience (since 2019), the rock s... Jan 31 2022, 10:15 AM
emerygt350 In minnesota, where it used to be regularly too co... Jan 31 2022, 12:48 PM
Superhawk996
In minnesota, where it used to be regularly too c... Jan 31 2022, 02:02 PM
wonkipop
In minnesota, where it used to be regularly too ... Jan 31 2022, 03:01 PM
wonkipop
In minnesota, where it used to be regularly too c... Jan 31 2022, 02:56 PM
JmuRiz Looks like my roads, brined before and salted duri... Jan 31 2022, 07:37 PM
Van B
Looks like my roads, brined before and salted dur... Jan 31 2022, 08:29 PM
Front yard mechanic In New Mexico we just toss dirt on the road in the... Feb 1 2022, 07:32 AM
930cabman
In New Mexico we just toss dirt on the road in th... Feb 1 2022, 03:25 PM
iankarr As much as I hate salt...sand might be worse since... Feb 1 2022, 01:46 PM
wonkipop there is a place in aus to drive on salt with a sm... Feb 1 2022, 03:56 PM
Superhawk996
there is a place in aus to drive on salt with a s... Feb 1 2022, 04:08 PM
wonkipop
there is a place in aus to drive on salt with a ... Feb 1 2022, 04:24 PM
emerygt350 When I lived in Washington DC we had an inch or so... Feb 1 2022, 07:41 PM
SKL1 Having lived full time in AZ for the last 2 years,... Feb 1 2022, 10:27 PM
914_teener I am in Northern AZ part time where in the Winter ... Feb 2 2022, 12:16 PM
Superhawk996
Be responsible and learn how to drive.
:rotfl... Feb 2 2022, 12:41 PM
914_teener
:rotf... Feb 2 2022, 01:42 PM
ClayPerrine
(I'm a civil engineer).
Remember, Mechani... Feb 2 2022, 02:59 PM
worn In the early spring here in Wisconsin, say late Ma... Feb 2 2022, 06:48 PM
wonkipop
I am in Northern AZ part time where in the Winter... Feb 3 2022, 12:44 PM
914_teener
I am in Northern AZ part time where in the Winte... Feb 3 2022, 01:56 PM
930cabman
[quote name='914_teener' post='29790... Feb 3 2022, 02:19 PM
flipb
Shame on the city of Pittsburgh, nothing short of... Feb 3 2022, 02:54 PM
914_teener
Shame on the city of Pittsburgh, nothing short o... Feb 3 2022, 04:37 PM
flipb Usually, even during the winter, we get at least a... Feb 3 2022, 10:13 AM
mlindner Funny worn, I think you've been cooped up to l... Feb 3 2022, 12:00 PM
914_teener
Funny worn, I think you've been cooped up to ... Feb 3 2022, 01:35 PM
emerygt350 That bridge in Minneapolis always scared me when I... Feb 3 2022, 03:40 PM
914_teener
That bridge in Minneapolis always scared me when ... Feb 3 2022, 05:01 PM
StarBear Getting back to salt.... My wife worked for a lo... Feb 3 2022, 06:35 PM
emerygt350 I used to deliver pizza in a dodge Omni during 50 ... Feb 3 2022, 06:36 PM
VaccaRabite Snow tires are the bomb. My WRX with a set of sno... Feb 3 2022, 07:04 PM
Shivers I live in the low desert in So. Cal, and we have s... Feb 3 2022, 07:12 PM
emerygt350 That hurts. We have 8 inches of old snow with a t... Feb 3 2022, 07:36 PM
targa72e I remember the discussion when I lived in Michigan... Feb 4 2022, 11:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th October 2026 - 06:41 AM |
